Blew the trans
not a terrible job...
first get the atsg manuals, they show how to air test the assembly.
if you replace the trans pump, do not turn yours in!
cup plugs are a pita.
factory service manual is required for some things like the cup plug locations... lol
do not buy or use no name parts!
the converter in my 84 had spacers for the converter setback.
watch for them and keep.
the 84 service manual had a mistake, the front roller clutch in the input housing was backwards!
Transmission did some weird things with that in backwards.
upgrade to the bonded pistons, nearly impossible to fk those up.
the early style lip seals are a pita, bonded pistons are soooooo much easier!
i did a shift kit in mine, trans clutches as tight as possible.
took a few tries to get it right, but it shifts super fast.
almost too firm at low rpm...
there is a rebuild vid avail on ebay, totally worth it imo.
eta, all of the later 4l60e parts are backwards compatable.
the atsg manual talks about them.
i have the later low/reverse piston as it had issues early on, i also installed the ear roller clutch assy from a 4x4 4l60e to match up, and it's an upgrade part.
i also have a 5 pinion planet set from a low mileage 4l65e (ebay find).
i forget some the actual names, too lazy to look it up, and it has been a while...
also the early trans had some oiling issues, especially at the planets.
upgrading those parts fixes it.
sonnax makes a super wide hd pump bushing.
i highly recommend it.
that bushing takes a real beating, causes pressure loss...
tons of other upgrade parts, sonnax website is pretty educational.
i also used some shims in the back of the trans to set the endplay..
my 84 had some serious slop.
nearly all of the clunk has been takenout of the trans as a result.
i recall they were sold as shims for a th400, but i think sonnax lists them for the 700/4l60 as well.
input shaft is weak where it presses into the drum, sonnax makes a ring to keep the splines from breaking.
pay special attention to the oiling holes.
you might have issues with the shaft vs pump.
you will want to bench test the assy on a bench to be sure all gears work.
atsg manual covers that.
You can do it with the parts stacked on a bench, out of the trans case.
remeber my mention about cup plugs in the pump, should you need to change the pump housing.
the factory service manual covers the locations, but it's drawn poorly.
(that's where the old pump is important)
the one piece seals are easy.
use a funnel to expand the seals for install.
then i used some 3m super 33 electric tape to compress.
wrap loose and then tighten while working with your fingers.
then leave to sit wrapped while until ready to install into the pump.
get a few sets, very cheap.
you might chew them up while bench testing...
also i watched some vids where they file on the pump bushing to prevent hangups on the teflon seals, don't do that.
those guys are dumb.
mine challenged the f out of me, all my tips are related to mistakes i made.
Transmission was the only thing that really scared me about my old vette.
Now it's just a weekend job for me.
Something unavoidable with higher stall t/q's is they produce more heat and heat is what kills an automatic transmission. So a good functional transmission cooler is nearly a requirement - unless you only race at the drag strip and trailer the car there.
My point here is I think you kill even a performance built 700R4 using a stock t/q and 3.07 gears. Rather than spend $700 on a smaller first gear I would spend that on a t/q, 3.73 rear gears set and a good trans cooler.
Hope this helps more than it hurts but you should spend a hour or two reading up on t/q's.
I was considering rebuilding a core 4L60E for my camaro and purchased quite a few "how to" books and manuals. Many times you can find a core trans that's not only a match but the owner is giving it away for the garage space. I read Cliff Ruggles book on GM overdrive's and the ATSG manuals. All were great reading though I didn't rebuild one. The Ruggles book talks quite a bit about torque converters and tool selection. The advantage to doing the rebuild yourself is not only labor savings but you know the parts that actually go into your trans. Even if you buy great parts for a rebuild how do you know if a rebuild shop doesn't pocket them and install the cheap parts in yours? The shop that finally rebuilt my camaro's trans said a hi-po kit went into it but only they really know. I asked to see my old parts and they showed me a oil pan full of parts including 2 planetaries. I recall only 1 planetary in a 4L60E. Oh well they gave me a warranty and the trans worked flawless for a year now.
One last option is to find a used 700R4 as even the pick a part near me gives a guarantee. And many times you can find a 700R4 in an old GM boat like a station wagon that you can buy the whole car for a song and test drive it too.
Good luck.
it was nice, a slightly looser converter woke the car up quite a bit.
after my pump blew up (no name rotor from the rebuild kit), i started chatting with fti about going with a different converter
per my cam they told me i should seriously think about a 4k rpm converter or higher.
me not sure, i went with the 3200 9.5in converter with lockup.
i love that thing, the smaller size made the engine snappy as f, revs super quickly.
that helps it get to the stall rpm very fast.
the car was transformed.
i can now get my tires to break loose at will (when cold), and i like having instant access to the powerband.
running that converter for about 2 years now, and the only thing i want to change is that 4k stall they talked about.
One day maybe... lol
There was only a slight adjust to the way i drive the car, crusing is the same.
i can still cruise at low rpm on part throttle no problem.
but when i hit the pedal, instant 3k rpm and I'm gone!
i also found i perfer to shift manually, my shift kit makes it most enjoyable. Lightning fast upshifts, and i have fun trying to rev match for down shifts.
the car is an event to drive now, and my exhaust system only adds to it...
when my pump went, i reassembled the pump to see how much was missing.
it was pretty bad, and the more i tore into the trans, i kept finding little bits of metal.
Also, what kind of cam do you have that builds peak power at such a low rpm?
maybe it's time to get a better converter, and plan on a different cam...
and as for your camshaft...
https://www.summitracing.com/parts/cca-08-302-8/
You need to have a chat with a converter manufacturer of your choice.
that camshaft would be very happy with a higher stall, like 3200 rpm or higher (4000+ if you felt good about it).
I went with fti, good value imo.
others will chime in with other options.
Converter can really make the car fun.
ETA: if you're anywhere near utah, I'll let you drive my car.
I'm 100% sure i can convince you to go with a nice loose stall and a small converter size.
