proper idle speed
Old Oct 23, 2019 | 10:25 PM
happyman2's Avatar
happyman2
Default proper idle speed
have a 1990 C4 of course and have a high idle issue. was in the Chevy dealership and asked them to set idle at proper speed.. it does have a 52 mm BBK TB. has headers with Corsa exhaust. a decent air filter also. was told i could not slow the idle down without the stock TB on it . i have to think that s little larger throttle body would not make it impossible to set idle correct.
Old Oct 24, 2019 | 05:48 AM
bjankuski's Avatar
bjankuski
Make sure there are no air leaks and then set the minimum idle speed. No issue with the BBK throttle body, just poor mechanic at the dealer.
Old Oct 24, 2019 | 08:05 AM
happyman2's Avatar
happyman2
and how do we set idle .
Old Oct 24, 2019 | 09:04 AM
bjankuski's Avatar
bjankuski
-Warm engine up
-Turn off
-Jump the A to b terminal in the diagonistic connector together
-Turn key on and get out and disconnect the idle air connector on the thottle body
-Turn key off
-Pull out jumper
-Start car and adjust the idle screw on the BBK throttle body until you have 550 RPM at warm idle
-Turn car off and plug connector back in
Good to go
Old Oct 24, 2019 | 09:50 AM
happyman2's Avatar
happyman2
Thanks you!
Old Oct 26, 2019 | 11:01 PM
aklim's Avatar
aklim
I much prefer to set it using the IAC counts since it also warns me of an air leak if I cannot adjust it. You can set the idle speed by going through the ECM. If the program is right, I would try find the problem in the system. At closed loop and idling with everything but the motor off, I scan the IAC counts. Target is 20-30. If it is more than 30, the ECM needs air. Turn the screw in and rev and recheck after it settles down. If it is less, turn the screw out, rev and recheck. This would bypass all the guesswork. The FSM method relies on a perfect system. No leaks, everything is functioning INCLUDING THE TACH which might not be accurate.
To proper idle speed
