Prom chip
Old Oct 28, 2019 | 09:49 PM
Bigmike4098's Avatar
Bigmike4098
Default Prom chip
Hey guys I think my prom chip mite be bad. Is there any really way to trouble shoot it. Or do I just need to get a new one. If so where is a good site to get one. Just stock no upgrades
Old Oct 28, 2019 | 10:38 PM
Kevova's Avatar
Kevova
Proms don't fail very often. May set a DTC. ECM fails more often. Custom and stock proms can be made. Discribe what's happening?
Old Oct 29, 2019 | 02:01 AM
Bigmike4098
Ok my car is a 89 with a l98 6speed. Now when I'm going down the cruising it's fine. But when I push the throttle to half way or better the car will start to stutter and miss. Ease back off the just before half throttle it will quit. But anything past half throttle it stutters and misses. The car take about 6 to 7 turns before starting when cold and 4 to 5 when hot.
Now I have replaced everything under the hood but my injectors. And iv replaced my ecm. My ecm did have a short, because my miles per gallon gauge didn't work. When I replaced the ecm it started working. So if the ecm had a short maybe the prom chip mite aswel .
also I have plenty of fuel pressure at the rail about 41psi even when its stuttering. And the dizzy is set right and tps is set right. It has no vacuum leaks. And every cylinder is firing. I think I covered most of it.
Old Oct 29, 2019 | 10:44 AM
vader86's Avatar
vader86
Really would like to see what a scanner says when you are giving it some throttle. If the pressure is holding, is it detecting knock and pulling all the timing out?
Old Oct 29, 2019 | 01:26 PM
Bigmike4098
I cant get my friends scanner to connect to it.
Old Oct 29, 2019 | 01:28 PM
Bigmike4098
With the fuel pressure gauge hooked up while driving the pressure says constant.
Old Oct 29, 2019 | 02:37 PM
Tunedport90's Avatar
Tunedport90
Did you ohm your injectors warm yet ?
Old Oct 29, 2019 | 05:42 PM
Bigmike4098
No sir I have not. What should the ohm reading be around?
Old Oct 29, 2019 | 05:55 PM
Tunedport90
15.5-16.5 warm
Old Oct 29, 2019 | 06:34 PM
Kevova's Avatar
Kevova
Restricted exhaust. Loosen nuts on down pipes at manifolds or remove O2 sensor drive it see what it does.
Old Oct 29, 2019 | 06:59 PM
Bigmike4098
It's dont have cats, done cut them out.
Old Oct 29, 2019 | 07:50 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sub'ed
Old Nov 1, 2019 | 06:30 AM
Bigmike4098
Ok ohm out my injectors they all around 14.9 to 15.1 and that is while its hot. The only thing I can think of now is my prom chip. Where can I get one?
Old Nov 1, 2019 | 07:36 AM
Kevova's Avatar
Kevova
It's unlikely to find NOS part. PCM of NC or anyone with the stock files and chip burner could make one for you..
Old Nov 1, 2019 | 09:02 AM
Tunedport90
Www.tunedperformance.org
i don’t think it’s the memcal. Sounds heat related.
Old Nov 1, 2019 | 05:47 PM
ghoastrider1's Avatar
ghoastrider1
Tpi ?
Old Nov 2, 2019 | 12:07 PM
Bigmike4098
Yes sir it's a tpi.
To Prom chip
