MSD Digital 6 problems?
Old Nov 14, 2002 | 08:08 PM
red-y's Avatar
red-y
Default MSD Digital 6 problems?
Has anyone had problems with the MSD Digital 6 retard system. I am on my third one, well I should say my last one. This system sucks and keeps going out. Any comments?? :confused:
Old Nov 14, 2002 | 08:44 PM
95AquaC4's Avatar
95AquaC4
Default Re: MSD Digital 6 problems? (red-y)
Mine works great!! (knocking on wood.)
Old Nov 14, 2002 | 08:56 PM
scorp508's Avatar
scorp508
Define what your problems are.
Old Nov 15, 2002 | 01:36 PM
krivera's Avatar
krivera
Yes, You have to reset it i think...i am not sure but everyone i know you have to disconnect the bat and get everything wired then connect everything at one time? did you install it with the Bat connect hot? I am not sure if that is the problem with it not working but did it make your car run worse when it was installed? Just my .02 cents
Old Nov 15, 2002 | 07:23 PM
black bart's Avatar
black bart
If you don't learn to follow directions you will have the same problem wih another brand. The fact that you have a problem with three tells me you installed it wrong you didn't get three bad units. MSD is the best ignition system on the market people run them trouble free for years. Have you called there tech support for help or are you just installing all of them the same way :nopity
Old Nov 16, 2002 | 05:38 PM
red-y's Avatar
red-y
Default Re: MSD Digital 6 problems? (black bart)
Interesting - I have had each one installed at different shops. Towed it back twice on the last break down I disconnected it and wired around it to get home. :mad
[Modified by red-y, 4:47 PM 11/16/2002]
Old Nov 16, 2002 | 05:46 PM
red-y's Avatar
red-y
Default Re: (scorp508)
The car has died while driving. the first time I had the Opti replaced and the shop said that the dig 6 was bad also. The next time it acted like the opti, just quit and would not turn over, but it was the dig 6 again. The last time the car just quit and turned over but would not start. Three different shops installed each one. I am sending it back for repair and inspection, anyone want to buy it when I get it back? :(
Old Nov 16, 2002 | 06:09 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: (red-y)
where is the unit mounte don your car?
Old Nov 16, 2002 | 06:12 PM
scorp508's Avatar
scorp508
I find it really hard to believe you got 3 bad units in a row. If that is true that is horrible. Where are you getting your 12v switched supply from? Are your main 12v hot at all times and ground going directly to the batter or somewhere else?
Old Nov 17, 2002 | 11:08 AM
red-y's Avatar
red-y
I will check it out and go over the instructions with the current shop. Currently it is out of the car. Thanks for your input. :seeya
Old Nov 17, 2002 | 11:11 AM
red-y's Avatar
red-y
Default Re: (bill mcdonald)
First it was mounted in the rear inside the car. The second and third ones were mounted in the left side front under the headlight in the fender well.
Old Nov 29, 2002 | 04:29 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Is this system different than the MSD 6A??????
Should I get this instead of?????
thanks
:smash:
Old Nov 30, 2002 | 11:49 AM
scorp508's Avatar
scorp508
Default Re: MSD Digital 6 problems? (oldace84)
Yes it is a different one. This one costs about $270 and has a few more features. Its up to you if it is worth it. Some people won't use all of htem.
Old Dec 3, 2002 | 05:28 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: MSD Digital 6 problems? (scorp508)
I had my MSD 6AL go out on me a couple weeks ago. It lasted over 3 years so I would say that I got my money worth. I may go up to the Dig 6 on the next one.
It is very odd you would have 3 in a row go out.
Old Dec 11, 2002 | 08:52 PM
red-y's Avatar
red-y
Default Re: MSD Digital 6 problems? (Vette92)
It is odd but believe me it happened I have the receipts to prove it. My car has been a nightmare since May but it is all re-built and getting some miles on the new engine. Dyno'd at 320 RWHP so with the gas I have another 100 RWHP - plenty of HP. Should be around 510 at the engine and 420 RWHP. Installed an Ed Wright chip and planning a trip to Tulsa to have Ed fine tune the chip after the Holidays. Running a little rich and the torque converter is not quite right. Looking forward to the road trip to bad it's Tulsa.
It is a different car for sure. Not your Mother's Chevy.. :cheers:
To MSD Digital 6 problems?
