Hub/Balancer tool...
Old Nov 15, 2002 | 08:17 AM
tomservo's Avatar
tomservo
Default Hub/Balancer tool...
I am trying to install the balancer hub on a new short block, and am running into some trouble. First off it looks like the "snout" of the crank is actaully shorter than the "shaft" of the hub, by about 3/16". This seems odd to me. Also I am having a heck of a time putting it on. The Haynes manual references a tool to remove/install the hub, has anyone seen one of these or have any idea where I could get one? Has anyone run into this problem before?
Old Nov 15, 2002 | 08:28 AM
350camaro's Avatar
350camaro
Default Re: Hub/Balancer tool... (tomservo)
I have seen some install / removal tools in the summit racing and jegs catalogs. I have the fluid damper tool which only works on the small block chevy, it works great.
[Modified by 350camaro, 1:31 PM 11/15/2002]
Old Nov 15, 2002 | 12:01 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Hub/Balancer tool... (350camaro)
I puchased a fluiddamper...street damper...have not installed it yet....Bought it from JEGGS.
What tool from fluiddamper are you refering to....Where to buy???
Cost???
thanks
tony
:smash: :smash: :smash: :smash:
Old Nov 15, 2002 | 12:55 PM
350camaro's Avatar
350camaro
Default Re: Hub/Balancer tool... (oldace84)
I bought mine from summit but that was 3 years ago. I looked on the summit web page and the fluid damper page, it looks like they don't make it any more. Summit sells a universel one but it is expensive, the one I got was around 45.
[Modified by 350camaro, 5:58 PM 11/15/2002]
Old Nov 15, 2002 | 12:57 PM
350camaro's Avatar
350camaro
I bought mine from summit but that was 3 years ago. I looked on the summit web page and the fluid damper page, it looks like they don't make it any more. Summit has a universel one but it is expensive.
To Hub/Balancer tool...
