Help needed
Old Dec 4, 2019 | 10:40 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Default Help needed
Hi, just found this connection, what is it for? Anyone knows?
TIA
Old Dec 4, 2019 | 10:41 AM
ZEROVETTE7's Avatar
ZEROVETTE7
It was under the distributor in the back of engine ...
Old Dec 4, 2019 | 11:14 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Does your tach work?
Old Dec 4, 2019 | 11:45 AM
ZEROVETTE7's Avatar
ZEROVETTE7
no it’s not... so it’s for that
but where does it go?
Old Dec 4, 2019 | 12:43 PM
Cruisinfanatic
Does the dash work except for the tach?
That wire goes to the tach filter mounted to the bell housing area in back of the distributor.
You'll need to take the wiper motor off to even see it. The brown wire is obviously off it. There should be another one on it hopefully.
Old Dec 4, 2019 | 12:46 PM
ZEROVETTE7's Avatar
ZEROVETTE7
thanks 👍🏻
I’ll try and look for it
Old Dec 4, 2019 | 02:35 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
that goes into the distributor beside the pink wire with the wite terminal.
To Help needed
