Another Drone Thread...
Old Dec 31, 2019 | 08:01 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My experience with Rose. Stock 86e, Dumped the OEM mufflers custom fit a set of Borlas to the OEM catback tubes. Replaced the factory CAT with a Magnaflo. Eliminated the front CATs using an 85 exhaust Y pipe. Resulted in a notable drone in the crusing range. Swapped cam, 1:6 rockers, custom tune. The drone was gone. Go Figure
Old Dec 31, 2019 | 09:48 PM
Jaye Bass's Avatar
Jaye Bass
Cam for sure changes the frequencies of the exhaust pules which is what causes the droning.
Old Jan 1, 2020 | 10:03 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by RetroGuy
Hence spend a little extra now, and don't worry about drone again.
Wisdom. I'm reminded of a quote that my grandfather used "Some people enjoy scheming against the inevitable..." Drone elimination is an easy fix.
Old Jan 4, 2020 | 10:19 AM
RetroGuy's Avatar
RetroGuy
Obviously drone is mostly an issue for daily drivers or while driving our Vettes on trips, not racing. I consulted the techs at Corsa, and they stated that every one of their models, Cat-back or Axel-back (Sport or Extreme sound) will NOT drone. Apparently they did a lot of R&D to achieve this with our Corvette engines. Their Cat-back systems, which includes an X-pipe, is supposed to have a bit more performance...per the techs. I'll definitely buy a Corsa for my next non-racing Vette and not have to cross my fingers regarding drone.
Old Jan 4, 2020 | 12:47 PM
bud40oz's Avatar
bud40oz
alpine.... cure for all drone noises.. lol
but seriously, i hope this new pypes exhaust i just bought doesn't do that, i will be pissed
Old Jan 4, 2020 | 01:39 PM
billschroeder5842
Bud, you will have a good idea before your install.... what type of mufflers do you have? If your mufflers follow the "sound absorption" engineering you will have drone at certain rpms. If your have mufflers are " pressure wave cancellation" you will not have drone.
BTW... Corsa and OEM are "pressure wave cancellation"
Old Jan 4, 2020 | 11:28 PM
aklim's Avatar
aklim
IIRC, there was a article that said Corsa was definitely more efficient than OEM so not sure why it happened since they use the same form of cancellation.
Old Jan 5, 2020 | 11:27 AM
billschroeder5842
Could be.... I'm not sure. I suppose it could be how they "tune" the wave. In ZR1 land, they did a comparison on Corsa vs OEM mufflers and found that the OEM had about 5hp more restriction than the Corsa at WOT. However the Corsa sound different than the OEM probably due to that straight flow through of the muffler exhaust rather than a zig-zag through chambers?
Old Jan 5, 2020 | 03:29 PM
JrRifleCoach
Is this the rear Y pipe that includes a crossover tube?
If so I found there is no difference in sound nor power.
YMMV
