96 - Climate Control Issue
Old Jan 28, 2020 | 09:53 PM
jakey1999's Avatar
jakey1999
Default 96 - Climate Control Issue
My 96 CE AT heat works fine at start but gradually gets cooler the longer I drive. After a period of time it starts to feel cool, and I need to bump up the temperature to about 81 and above to get it warm again. Just flushed the coolant and heater core and added a new thermostat (180). Also, there are no climate control codes displaying (shows "00").
Any ideas?
Thanks,
Old Jan 28, 2020 | 10:25 PM
s carter's Avatar
s carter
Try running in the Recirculation mode, in automatic mode your car is cold it pumps heat and as the car gets warm it cuts back. Or at least that's what my car seems to do.
Old Jan 28, 2020 | 11:11 PM
jakey1999's Avatar
jakey1999
Re-circulation also blows cool until temp is 81 degrees and above.
Also, noticed when in defroster mode air is not blowing from the front windowshield vent. Maybe it's a climate control module issue?
Old Jan 28, 2020 | 11:17 PM
s carter's Avatar
s carter
Definitely a possibility, I had replace it in my car. In my case a/c compressor wouldn't run and vents were a little tempermental.
Once I got it off the firewall opened the back of it lots of Corrosion and I think a cracked board. So I threw in the one I found.
Old Jan 29, 2020 | 10:09 AM
pcolt94's Avatar
pcolt94
My 94 does the same thing I have to keep bumping the temperature up to keep it warm. When I hit 85 that is the maximum regulation temperature it will regulate the blend door. After that, 90 it the next step up and it just goes full heat with no regulation. If you can stand the heat then you just have to take it till you get to hot. I found if I go back to 85 in time it starts to regulate. Definitely not the greatest heat controller.
Many have complained about this heater function. And it seems it does not matter what mode you are in, they all work about the same perhaps with a slight difference. That just seems to be how our cars function and we just have to deal with it.
Old Jan 29, 2020 | 10:56 AM
Oklahoma Adam's Avatar
Oklahoma Adam
I have the same issue on my 1990. Keeping an eye on this thread.
Old Jan 29, 2020 | 10:43 PM
jakey1999's Avatar
jakey1999
Thanks all. Will definitely keep checking back for solutions.
I think I'm going to tackle the ac programmer next as several others have.
To 96 - Climate Control Issue
