3D print files for c4
Edit: Here is the thingiverse link to download the *.stl file
My hood prop rod end broke from user stupidity. Modeled it in fusion360 and printed on an Ender 3 in PLA @ 200deg C nozzle and 60deg C bed temps. It's very strong. I uploaded the files to Thingiverse, but it takes 24hrs to publish so I'll reply with the link later.
I had the convertible top on my 1996 CE replaced a couple years ago and the top edge of the rear window sat too low and was constantly sliding down off the plastic support piece. I designed a couple of slightly thicker support spacers on Autodesk TinkerCAD. I didn't take any pictures of the actual part but here's a screenshot of the design image. It's not even remotely as complicated as your hood prop end but there was a sense of satisfaction nonetheless.
Here's a link to it on TinkerCAD:
https://www.tinkercad.com/things/dN4...support-spacer
And here it is on Thingiverse:
https://www.thingiverse.com/thing:4158260
My '90 came with metal cup holder inserts.
If someone wants to build a plastic model of mine I can take more pics or measurements.
I bet if you printed of a couple sets you could charge $30 easy on Ebay etc. for them.
Good material to print out of isn't that cheap.
I have access to a 3D Scanner, 3D Printer, and Inventor. However, while it is not a primary business function it is still part of my business. I would unfortunately at least have to cover my cost of materials. If anyone wants to try creating something, you can PM me.
I kind of want to start a company called "The good one" where we just troll forums for popular vehicles (vettes, jeeps, motorcycles, etc.) and ask them about "The good one" piece that used to be available but no longer is. Every hobbyist forum has a few of these. For C4's no one likes the new style rear hatch lift bracket and talks about how much better the old one was.
In most cases there was one guy who used to be on the forum that made them for a couple of years but has moved on so now they are holy grail items.
The company would just make batches of these holy grails at 100 per batch.
Seems like the hard work would be just recreating them in CAD then modifying them enough not to step on any patents.
You're not going to be the next Amazon but I think you could charge a real premium for them and make some money with pretty low overhead.
I am not a naysayer though, I would be more than happy to see you prove me wrong and be successful at it. I have all the resources to do the small parts as my printer is not very big, but I don't have the time to troll for what should be made. Happy to work with someone to make the parts if someone has a need.
I have a couple pieces I've made. I'm working on a washer nozzle since it can't be purchased separately from the arm.
We probably need to get input from the mods on replicated parts as they may be patent infringement. Also copyright on logos. Accessories should be fine
Hosting the files on thingiverse with the personal use license deals with people taking your file and selling prints on ebay.
If you haven't ever modeled anything watch this. Its using a program that is free to hobbyist but if you start selling designs it has a pretty hefty licensing fee.
Typical patents are good for 20 years from the filing date and there are maintenance fees. I'm not a lawyer and don't play one on TV, but I'm guessing the plastic bits on our C4s are no longer protected.
I don't know how big the printer beds are, but the first piece that comes to mind is the FRIGGIN BREAD BOX. How about a glove box? Don't know about a whole piece but what about pieces that can be assembled? I'd pay for that.
last time i looked into 3d printing for a business i owned at the time, the way that these 3d printer prts come out, they leave a stepped surface. like pyramids.
A person can sand or mist coat acetone on them to smooth them out. but thats a pita.
i could see an insert working for double din applications in early and late c4’s
Also, the plastic can be sanded smooth and painted fairly easily if you wish to achieve a truly smooth finish.
I have a Objet30 from Stratasys. BUILD SIZE
294 x 192 x 148.6 mm (11.57 x 7.55 x 5.85 in.)
LAYER THICKNESS
28 microns (0.0011 in.); 16 microns for VeroClear material (.0006 in.)
ACCURACY
Typical deviation from STL dimensions, for models printed with rigid materials, based on size: under 100 mm – ±100μ; above100 mm – ±200μ or ± 0.06% of part length, whichever is greater.
BUILD RESOLUTION
X-axis: 600 dpi; Y-axis: 600 dpi; Z-axis: 900 dpi
LAYER THICKNESS
ACCURACY
BUILD RESOLUTION
Here are a few other samples of what I have made with the 3D printer. All of this has some age to it. You can see how it pics up dirt, especially in areas where support material was. If I was going to use this in my car, I would defiantly sand, primer, and paint. Even if it was a flat paint to protect the appearance.
We use this blue for everything because it is pretty hard and tough as well, but like any plastic, give it Sharp edges or let it get too thin and it will crack.
You can also see remaining support material during fitment and what they part can actually look like after a being hit with a pressure washer. Another note, you will see in the 3D part is how thin a section of the wall got. This didn't show up in the 3D model to be as big of an issue as what it was once visible printed out. The pressure washer actually blew the material away from these areas. So, it was corrected before the final design.
