Throttle position sensor problems
Old Mar 20, 2020 | 03:13 PM
Aidan652's Avatar
Aidan652
Default Throttle position sensor problems
Hi all, I was wondering if you guys knew how I could fix my TPS problem. It’s throwing code 22 and I have replaced my sensor once. And the previous owner had replaced it before I got it as well. Which was roughly a year ago. The new sensor has been in for about 6-8 months. How can I find out the source of my problem? Wires and tps looks good visually. (Car is a 1987 Corvette). Thanks!
Old Mar 21, 2020 | 11:48 AM
Brandonvette's Avatar
Brandonvette
did you set the voltage to 0.54 after install ?
Old Mar 21, 2020 | 12:12 PM
Aidan652's Avatar
Aidan652
i had a friend help me do it and I don’t recall him doing that. How do I do that?
Old Mar 21, 2020 | 12:50 PM
jazfe's Avatar
jazfe
Aidan652,
Lots of post here on how to set the TPS. Just do an advanced search for TPS setting.
Old Mar 21, 2020 | 01:37 PM
Brandonvette
You need volt meter. Then put it in the back of the plug wile still plugged in . The top two wires . Turn key on but don't start and lose bolts and move till you get .54 volts it's really easy
Old Mar 21, 2020 | 02:43 PM
Aidan652's Avatar
Aidan652
Great. Thanks guys!
Old Mar 21, 2020 | 07:07 PM
Deepa's Avatar
Deepa
What brand tps? Ac delco is the only way to go
Old Mar 21, 2020 | 09:05 PM
Aidan652's Avatar
Aidan652
Yep it’s AC Delco
Old Mar 21, 2020 | 10:23 PM
GregMartin's Avatar
GregMartin
After you set zero throttle check WOT It should be over 4V, I think mine is about 4.6 from memory. All the info is in the FSM.
Old Mar 21, 2020 | 11:25 PM
xrav22's Avatar
xrav22
I was sticking pins into the top 2 wires but since broke down and bought wire piercing tool. Makes it a bit easier to do.
.54-.56 probably ok for computer.
Good Luck
Old Mar 22, 2020 | 11:40 AM
Aidan652's Avatar
Aidan652
Good Luck
should I be sticking it into the plug connector or the actual tps prongs?
Old Mar 22, 2020 | 11:46 AM
Brandonvette
The back of the plug where the wires are goin in to the plug while it's still plugged in to the tps you tube a vid you'll see
Old Mar 22, 2020 | 11:58 AM
xrav22's Avatar
xrav22
Old Apr 20, 2020 | 12:25 PM
jh-pop's Avatar
jh-pop
Hi, very useful article. Please can I still question, setting 0.54 is when the engine is hot or cold. Thanks for the message
Old Apr 20, 2020 | 01:26 PM
xrav22's Avatar
xrav22
https://www.digitalcorvettes.com/thr...your-c4.58873/
Old Apr 20, 2020 | 01:41 PM
jh-pop's Avatar
jh-pop
Thank you for the information . I know the procedure and I applied it. However, the voltage varies slightly depending on the motor temperature. Is the sensor bad? Thanks
Old Apr 20, 2020 | 01:45 PM
xrav22's Avatar
xrav22
I always do it hot, just check it by turning it up and the volts will should go up. Mine was really bad as I was tightening it the volts were bouncing all over. With a new one tightening did not affect volts.
Old Apr 20, 2020 | 01:55 PM
jh-pop's Avatar
jh-pop
Yes, I put it in cold condition over pins. Then the engine warmed up and the value changed to 0.64 . With a warm engine, the measurement was 0.54, followed by 0.58 after measurement.
I'll try a better setup
To Throttle position sensor problems
