No power
Old May 5, 2020 | 02:52 PM
  #81
ctmccloskey's Avatar
ctmccloskey
Are any of them related to the MAF sensor? Your explaining how the car won't rev over a certain speed sounds like a MAF or a plugged catalytic. Have you tried a new Oxygen sensor yet?
Old May 5, 2020 | 04:03 PM
  #82
MarkB85vette's Avatar
MarkB85vette
Both of those issues were DTCs. It looks like the only way to check the Cat is to pull it. I will clean the MAF, and really clean the electrical connection as well. Thanks for the response.
Mark
Old May 6, 2020 | 01:02 PM
  #83
Theman5's Avatar
Theman5
Originally Posted by MarkB85vette
Hello all,
my 85 has 16 DTCs, not sure where to start but low voltage may be a key. I will start cleaning contacts. Any advice on where to start will be very helpful. EST is my starting point. Code 41 is for that. I found my EST connector gone and that wire had a house hold wire nut on it. I crimped a connector there but not an OE connector. This I think could be a big part of the no power issue. Code 51 is a big one as well. I don't want to waste anyone's time putting all 16 here. Thanks in advance for any advice.
So you got a reader or the panel working?
Old May 6, 2020 | 09:48 PM
  #84
MarkB85vette
I bought a Innova scan tool that is OBD1 compatible and gives real time data. Still do not have the center console part fixed. I am going through cleaning every electrical connection I can get to.
Old May 7, 2020 | 08:15 AM
  #85
Theman5's Avatar
Theman5
You cleared codes and these came back as current real ones?
Old May 7, 2020 | 09:12 AM
  #86
MarkB85vette
I did not do that, I will clear them and then verify. Thanks
Old Jul 29, 2020 | 10:22 PM
  #87
MarkB85vette
Default DTC Question
Hello all,
After a long time of diagnostic work I have gotten my car from 17 codes down to 6. The six are codes 25, 34, 41, 42, 44, and 51. What I noticed was, all of these codes possibly lead to needing an new ECM. I am going through them one by one with the FSM as my map. Should I just go ahead and replace the ECM. I know this may sound silly but if all of the sensors are good they all lead to an ECM replacement. I look forward to the groups wisdom on this question. Thanks, Mark
Old Aug 1, 2020 | 10:17 PM
  #88
Theman5's Avatar
Theman5
Hello all,
They have anything in common like grounds?
Old Aug 2, 2020 | 08:10 AM
  #89
MarkB85vette
That is why I am going through each one carefully, but based on the FSM, for each of the codes, if the sensor tests ok, then the ECM is faulty.
Old Aug 2, 2020 | 10:21 PM
  #90
Theman5's Avatar
Theman5
Or wiring to ECM
Old Aug 2, 2020 | 10:53 PM
  #91
MarkB85vette
Yes, I will get to that, I have six codes, I have time this week. I have gotten 6 codes to go away by cleaning up connectors, the car runs well and is getting good mileage, but when I step on it , no power.
Old Aug 5, 2020 | 04:28 PM
  #92
jazfe's Avatar
jazfe
When you changed the fuel pump did you clean all of the electrical connections there at the pump? Your fuel pressure readings are off to me. I have an 86 and the pressure is 43 with vacuum and 50 without vacuum.
Old Aug 5, 2020 | 05:54 PM
  #93
GregMartin's Avatar
GregMartin
85s run different fuel pressure and different injectors to 86s. They are a one year only deal.
Old Aug 5, 2020 | 08:55 PM
  #94
gerardvg's Avatar
gerardvg
Hi
Your fuel pressures are fine the 85 runs lower pressures to later years as your injectors are 24lb, do not trust your harmonic balancer the hub can spin if the rubber bond has broken down. Double check the no1 piston is actually at top dead center, when at tdc on the timing tab.
Check your knock sensor wire is connected and not shorted to the block anywhere, disconnect your battery and reconnect (or the ecm connector near battery) to reset any codes as the ecm can get itself in knots trying to compensate for any perceived problems.
Is usually my first thing to do now as that fixes most of my rough running issues, do not forget your coil it needs spark energy to rev.
The connector at the bottom of the coil through to the rotor button can wear, i have had one cap fail in a big way with the arcing putting a hole there.
Good luck
Old Aug 6, 2020 | 12:01 PM
  #95
MarkB85vette
Thanks for the guidance. My distributor is all new to include the ignition module and all of the wiring is new. She fires right up, and is getting great milage. No power when you step on the gas. Slow acceleration and the car speeds up nicely and shifts gears. As for the knock sensor, I cleaned all of the connectors and ensured there were no shorts to ground and that code went away. The MAF is the next code to dig into after the MAT. From what I am seeing, I am confident that one of the offending sensors will be identified. I will let you all know how it goes
Old Aug 6, 2020 | 05:59 PM
  #96
Theman5's Avatar
Theman5
Can you look at live data or just pull codes ?
Old Aug 6, 2020 | 06:59 PM
  #97
MarkB85vette
My scan tool, is an Innova 3200, it does not look at live data with OBD1. I am pulling the codes and following the FSM.
To No power
Old Aug 6, 2020 | 07:36 PM
  #98
gerardvg's Avatar
gerardvg
No power can be caused by fuel pressure or retarded ignition, i had a fuel pump that was on the way out and only symptom was the car would not go past 60mph.
as long as you have 4.5vdc with the tps at full throttle ignition on, then if fuel pressure and tps ok the MAF will be the next thing to check.
Old Aug 7, 2020 | 08:49 AM
  #99
Theman5's Avatar
Theman5
I am surprised it won't show any live data. You could view when driving while issue is there.
I am having trouble finding that model in my searches??
Old Aug 8, 2020 | 08:25 AM
  #100
MarkB85vette
I was wrong, the Innova model is a 3120. As for the fuel pump, it is brand new, fuel filter is brand new, and my fuel preasure is within limits. My timing is set to 6°BTDC. I agreed that the MAF is likely. The MAF burn off module is proving to be hard to find for my 85, should that be the issue. The FSM says to check function of that before replacing MAF. This blog has really helped me learn a lot about my vette. I will get to the bottom of it. This weekend I should have time to do more detective work.
