VATS bypass module/chips
Old May 3, 2020 | 03:46 PM
c4 40th's Avatar
c4 40th
Default VATS bypass module/chips
Been having on and off problems with starting my car. Depends on when it lets me run my car may work one minute and then not the next, I never know when it'll let drive it. I have found three different options: pcmofnc.com, Howellefi.com, and Gm vats bypass moule on amazon. Has anyone used any of these with success? I really would like to use my car without knowing if it will restart if i stop somewhere with it. Right now I only take it for a ride the bring it home without stopping because of the problem. The last I took it out I had to leave it at work for three days before it would start again. Thanks
Old May 3, 2020 | 06:04 PM
RalfKramden's Avatar
RalfKramden
I installed the GM vats unit. Fairly simple, eliminates the need for a key resistor. Biggest problem was getting the $()&@ing breadbox out! I think you can do it if you remove the
dashpad, but I was replacing the breadbox with a flat panel. In this thread (https://www.corvetteforum.com/forums...orkaround.html)
the OP gives a great walk-through to install it. I followed his instructions and it worked perfectly. Good Luck!
Old May 3, 2020 | 09:42 PM
c4 40th's Avatar
c4 40th
Default Reply to RalfKramden
Thanks for the reply I'll be ordering that unit and give it a try. Right now i have the plug in key resister, which i thought it would fix the problem but that didn't happen. So its a lets try this something has to work, weather getting better and i want to use my car. Again Thanks
To VATS bypass module/chips
