EST and timing
Old Jun 26, 2020 | 03:40 AM
jseremba's Avatar
jseremba
Default EST and timing
Hello Everybody, I am working on my 1985 4 plus 3. When you are setting the timing. You disconnect the EST. When you are done and plug the EST back in what happens or should happen to the timing. Does it advance/retard. If I accelerate the engine the timing should advance correct. Thank you all
We set the idle and timing. When we accelerated the engine the timing did not advance. Any and all ideas are welcomed.
Old Jun 27, 2020 | 02:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm pretty sure it will immediately advance soon as you reconnect the EST.
Yes the ECM advances timing with engine rpm as the plugs need fire earlier as engine speed increases because the speed of the flame front is (relatively) constant.
Old Jun 27, 2020 | 02:32 AM
jseremba's Avatar
jseremba
Thank you. The general consensus is that the timing should advance when the EST is connected. And definitely when the car is throttled. We are going to pull the cap and make sure all of the wires are good.
Thanks again
Old Jun 27, 2020 | 08:20 AM
GregMartin's Avatar
GregMartin
On an 84 nothing happens when you plug the EST back in until you turn the ignition off then back on. Then the ECM handles the timing. I thought the 85 was the same.
Old Jun 27, 2020 | 08:59 AM
jseremba's Avatar
jseremba
I thought the timing would advance when we throttle the car. It doesn't
Old Jun 27, 2020 | 09:04 AM
84 4+3's Avatar
84 4+3
With the est disconnected throttle should still advance the timing a little. Confirm that first. Takes 1500 rpm or so to do it.
On a restart timing should run in base for a period of time (est connected) then the computer should advance it. With the wire connected timing at idle should be beyond the timing marks.
Sounds like something isn't working. Do you get a check engine light with the est wire off?
Old Jun 27, 2020 | 09:09 AM
jseremba's Avatar
jseremba
I will take a look at what you said
With the wire off the CEL comes on.
Thank you
Old Jun 27, 2020 | 09:18 AM
GregMartin's Avatar
GregMartin
Did you turn it off and on? There is a bit of advance in the module, but you have to turn it off and back on for the ECM to take control. Then the car will idle at something around 20 deg instead of 6deg.
Old Jun 27, 2020 | 09:25 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
For sure !
Old Jun 27, 2020 | 06:43 PM
jseremba's Avatar
jseremba
What we did was follow the timing procedure. IDI am going from memory sotso if it is not correct forgive me. Disconnected the IAC, turned on the car, waited 45 seconds. Start the car check/set the timing. Plug in EST. The timing stayed at 6 deg. My mechanic said it should have advanced to 19 deg. Then we throttled the car and the timing still didn't advance.
we are going to check the wires to the module.
Thank you for the help
Old Jun 27, 2020 | 06:47 PM
GregMartin's Avatar
GregMartin
ok one more time
after you plug the est back in you NEED to turn the engine off and on before the ECM will manage the timing. What part of this don’t you understand?
Old Jun 27, 2020 | 06:55 PM
jseremba's Avatar
jseremba
Sir, that is so rude. Like I said I was trying to tell you we followed the FSM procedure. But, I am recalling what we did. I believe we had to jumper A and B on the ALDL. And wait 45 seconds so the ECM would go into diagnostic mode.
have a good night.
Old Jun 27, 2020 | 07:28 PM
GregMartin's Avatar
GregMartin
have a good night.
I sorry you think it’s rude but I’ve said it three times now and you seam to be missing the point. A jumper between A and B is irrelevant with regard to setting the timing. So x4 after you reconnect the EST the ECM will not manage the timing until you switch the ignition off and then restart the car.
Old Jun 27, 2020 | 10:41 PM
jseremba's Avatar
jseremba
I sorry you think it’s rude but I’ve said it three times now and you seam to be missing the point. A jumper between A and B is irrelevant with regard to setting the timing. I am not missing the point and I appreciate your frustration. The point I was making. Is that if what you are telling me to do is the FSM procedure we did it.
So x4 after you reconnect the EST the ECM will not manage the timing until you switch the ignition off and then restart the car. The next time I am at the car I am going to heed what you are saying. Interestingly enough. The car idled very good yesterday. So I am thinking that being the car was off and now is restarted the ECM is now managing the timing. AS you stated it would.
So let me ask you.
I go to the car. Start it. connect a timing light. The EST is connected.
The timing mark is at 6 or is it advanced?
I throttle the car.
The timing should advance correct.
Thank you for staying with me on this
Old Jun 28, 2020 | 02:16 AM
Hot Rod Roy's Avatar
Hot Rod Roy
What we did was follow the timing procedure. I am going from memory so if it is not correct forgive me.
Sir, that is so rude. Like I said I was trying to tell you we followed the FSM procedure..
You started off good, but then the conversation got confusing. You said you went from memory of the FSM procedure, but your description sure didn't follow the FSM! On what page of the FSM describes your procedure? Do you have a genuine FSM, or one of the generic Corvette books?
I'm not trying to be rude, but I think you owe Greg an apology.
Old Jun 28, 2020 | 02:39 AM
jseremba's Avatar
jseremba
Good questions and thank you for the help. My mechanic looked up the timing setting procedure for the 85 Corvette.
I did not see the page.
We had to jumper A and B on the ALDL and wait 45 seconds. I thought that was to put the ECM in diagnostic mode, I may be wrong.
We set the timing with the EST disconnected and then reconnected the EST. According to Greg. I think we should have shut the car. And on the restart the ECM would set the timing. And like I said I think that is what happened because on the next day my mechanic started the car and it was idling better. So I think. That what Greg said is what occurred.
I never realized that the car had to be restarted in order for the setting to be registered by the ECM. Frankly I do not think that the procedure said that.
With respect to my conversation with Greg. I was not ignoring him. Which is what he thought I was doing. The car is not with me. It is in a shop that is locked up. I do not have access until Monday here. I appreciate all of the help you guys offer. I truly do. And, I do not ignore you.
Now that the ECM is most probably controlling the timing, being the car has been on and off.
If I turn on the car with the EST connected.
Where will the timing be 6 deg or 19/20 deg.
If I throttle the car above 1500 rpm.
The timing will advance, correct.
Thank you
So please let me ask again.
Old Jun 28, 2020 | 02:44 AM
jseremba's Avatar
jseremba
Greg,
I really do appreciate the help you guys give me. I felt you thought that I was ignoring you. I was not. If I were going to ignore people I would not ask for their advice and help. Sorry for the confusion.
To EST and timing
Old Jun 28, 2020 | 03:13 AM
GregMartin's Avatar
GregMartin
Yep that’s correct if you start it now the timing should be controlled by the ECM and idle somewhere around 20 deg (I cant remember exactly) and yes it will advance as you rev it. With regard to the other things, I’m only trying to help and sometimes tone doesn’t convey correctly in written text. I appreciate your response, don’t sweat it and hopefully when you put a timing light on the car next time the results will be as expected, if not we can work the next problem.
Old Jun 28, 2020 | 05:03 AM
jseremba's Avatar
jseremba
Greg, thank you for accepting my apology. I hate text and email. It has no tonality.
Hopefully I will get to work on the Corvette tomorrow. If I do I'll update you.
Thanks again
Old Jun 28, 2020 | 06:27 AM
GregMartin's Avatar
GregMartin
Thanks again
it’s all good mate I really didn’t mean to be rude but I can certainly see how It came across that way. These cars really are quite straightforward particularly with a FSM. There are plenty of people Here who will offer help willingly when things become ambitious.
