Please help
Old Jul 18, 2020 | 10:42 AM
lildog's Avatar
lildog
Default Please help
I have a 96 c4 get to point I keep going through I.c.m.s I have a new optispark put this last November, new ac delco coil,and new I.C.M . The car runs great for about 5 min then stops running and the code for the I.C.M comes back also with the new I.C.M no code can anybody help me
Old Jul 18, 2020 | 12:09 PM
Mrvettenick's Avatar
Mrvettenick
What do you mean by going through ICM's?
Old Jul 18, 2020 | 12:17 PM
lildog's Avatar
lildog
ignition control module
Old Jul 18, 2020 | 12:28 PM
Mrvettenick
Yes, I know that, but what is happening with them? Are you sure that they're failing?
Old Jul 18, 2020 | 01:00 PM
lildog's Avatar
lildog
This is the third one I replaced I put a new one on fire the car you runs great for about 10 minutes while it's running no code. Iet run until it warms up to test drive starts missing then it stops running. The I.C.M. code comes back. Then it will not start anymore ( as soon as I put a new I.C.M on it starts right up no problem.
Old Jul 18, 2020 | 01:08 PM
Mrvettenick
Have you measured the coil's primary and secondary resistance?
Old Jul 18, 2020 | 01:12 PM
lildog's Avatar
lildog
no i know doesn, t but its a new a/c delco coil i bought last week.
Old Jul 18, 2020 | 01:21 PM
Mrvettenick
The ICM's sole responsibility is to trigger the coil. That being said, there;s only two items that could cause repeated module failures....a coil with low primary resistance, or short in the primary coil control line. Just out of curiosity you should measure the resistance of the old and new coils. Did this problem come up after replacing the coil?
Old Jul 18, 2020 | 01:24 PM
lildog's Avatar
lildog
could the coil be messing them . how do you check the resistance from the coil .
Old Jul 18, 2020 | 01:43 PM
Mrvettenick
Just a thought....are you using the grease on the bottom of the module. That grease is to direct heat away from the module.
Old Jul 18, 2020 | 01:50 PM
lildog's Avatar
lildog
i think i still have the old one around some where ,but i only replaced the coil because p03571 came up and the coil had been on the car when it was new.ill go check the Resistance later its hot outside LOL.
Old Jul 18, 2020 | 01:54 PM
lildog's Avatar
lildog
to be honest i didn't on the first two didn't think it made that much of a difference ,but i did this time same results .
Old Jul 18, 2020 | 02:37 PM
lildog's Avatar
lildog
okay on the old one low -prim is 0.1 and the high is 6.25
Old Jul 18, 2020 | 03:03 PM
Mrvettenick
Spec should be 0,5 ohms on the primary. If your meter is correct, then that coil is bad, You really need to check the coil in the car at this point.
Old Jul 18, 2020 | 03:54 PM
lildog's Avatar
lildog
okay don.t have garage to hot outside . Got to work in the morning but next weekend ill check the one on the car .i want to thank you for your help and pointing me in thr right direction .
Old Jul 18, 2020 | 04:22 PM
Mrvettenick
No problem. Let's just do this one step at a time. I just don't like replacing parts without testing. Stay cool buddy!
Old Jul 25, 2020 | 06:26 PM
lildog's Avatar
lildog
okay i got up this morning checked the coil on the car ohms was 0.03 .charged the battery up the cranked started like nothing was wrong. there is a ac delco down the street from me i checked the ohms on a new one same reading .again about ten mins it ran and shut off .Let me add i changed the optispark in November it was the cheap slandered brand i,m thinking its the optispark . i read that another guy had the same problem .
To Please help
Old Jul 25, 2020 | 07:41 PM
Mrvettenick
When this thing cuts out, are you losing spark or injector pulse, or both?
Old Jul 25, 2020 | 07:48 PM
lildog's Avatar
lildog
yes
Old Jul 25, 2020 | 07:49 PM
Mrvettenick
Both?
