TP Sensor Learn Procedure
Old Aug 12, 2020 | 01:51 PM
AgentEran's Avatar
AgentEran
Default TP Sensor Learn Procedure
I have a P0123 and have determined I should perform the TP Sensor Learn Procedure as I have a new TB and TPS. FSM calls for a tech 1. Is this the only way? If so, how does one go about finding a shop that has a tech 1?
Old Aug 13, 2020 | 09:18 AM
fredk's Avatar
fredk
Use search, there are quite a few threads on this.
Old Aug 13, 2020 | 01:24 PM
AgentEran's Avatar
AgentEran
Indeed. I adjusted the sensor with the screws, all is good now.
Old Aug 14, 2020 | 08:49 AM
fredk's Avatar
fredk
Awesome
Old Aug 14, 2020 | 10:58 AM
Nomake Wan's Avatar
Nomake Wan
At present, the Tech 1 is the only way to perform the TP Learn procedure for the ASR computer. However, adjusting TPS for the PCM can be done with just an ALDL cable and a laptop with free software. Or a multimeter. But making sure that 0% is 0% and 100% is 100% is usually adjusting the cable, and again, actually seeing the live data from the PCM helps tons.
The pandemic has ruined my ability to reverse engineer the Tech 1 since I was 'borrowing' a shop one for that, but as soon as I can get my hands on another one, I plan to get all those ABS/ASR commands so that we don't have to pay hundreds for a Tech 1 or more for a shop to do these sorts of things for us.
Best of luck.
To TP Sensor Learn Procedure
