Is it safe to run that much boost thru a Base Engine: 350ci V8 240/245hp?
Its a procharger setup. I just think that it may be a ticking timebomb. I dont' know if the internals are forged or not.
Any links to info or info posted about superchargers and how much boost you can run on an engine? I don't know what determines the limits. I would assume that comp ratio would play a major role. All info is appricated ! :cheers:
oh and also we are at about 4500ft above sea level.
I have always thought of 400hp being the limit for the stock piston. I have read about people having problems with 10psi and stock pistons only lasting 10k miles, so your probably on the edge of long term reliability.
There is a big difference with 400 HP NA vs. 400 HP with boost.
Boost is what kills the cast pistons.
Detonation is what kills cast pistons (and boost is good way to create detonation) Either way anything over 400hp with the stock cast piston either by N2O, SC, Turbos, or NA is playing with the limits of the pistons.
I agree. Detonation is what kills, not boost. I ran 14psi on my old Mustang for 2 1/2 years, and about 200 drag strip passes and had absolutely no problems with the cast pistons. It all comes down to the tune. Cast pistons will leave you with less margin of error if your tune is way off, and you go lean or get detonation. The intercooler will buffer some of that, though.
But since I'm fairly new to Corvettes, you may want to listen to these guys. They probably have more first-hand experience with Corvettes and blowers.
thats exactly what I was thinking. I think it runs fast now around high 13's (remember this is in CO where C5's run high 13's but mostly low 14'). I just wonder for how long???
After seeing a friend melt the forged pistons in his Mustang SVO (2.3 intercooled turbo w/15psi) I am very cautious of buying anything with forced induction. Especially something that I don't know who did what to.
Thanks for the replys, its right along with what I was thinking. :cheers:
thats exactly what I was thinking. I think it runs fast now around high 13's (remember this is in CO where C5's run high 13's but mostly low 14'). I just wonder for how long. After seeing a friend melt the pistons in his Mustang SVO (2.3 intercooled turbo w/15psi) I am very cautious of buying anything with forced induction. Especially something that I don't know who did what to.
Just curious, what year was that Mustang ?
1985 - 1997 Mustangs had FORGED pistons ,that's why they have no issues with BOOST.
No Vic, you're WRONG. Mustangs came with factory forged pistons only through '92. The 93's had cast hypereutectic pistons, and that's the year I had. 94 and 95 also had cast pistons, not sure about 96+.
[Modified by fullboogie, 10:27 AM 12/3/2002]
Yep...exactly what he said.... I had a few 87-93 stangs over the years and had a supercharger on more than one. They could hold well over 10PSI with no problems. Even the 93's with the hypereutectic pistons. Justhad to be a little more carefull with the 93 and above models.
Ok, so I wasn't 100% correct. I am glad your 93 Mustang had no issues, but from my experience with L98's and supercharging, the cast piston will not last long.
Sorry if I came down too hard on you. I see a lot of posts that try to convice all who read it that supercharging will blow your engine up in a heartbeat. It's nonsense. If you know what you're doing and can tune a car, superchargers are safe. I know loads and loads of people who have them, race them, and cruise them, and don't know one person who's "holed a piston" unless the tune on the engine was WAY out of whack. Just trying to set the record straight.
If I remember my ProCharger lit correctly, 6psi boost with an intercooler will give you about a 40% HP gain. Starting with a stock 240hp engine that would be about a 100hp increase.
I realy don't see how that gain NA vs super charged would be any different (don't you have the same charge density to get the same HP??); of course if you get detination with either you're in trouble. Any clarification on this one please??
Now I can see where assuring proper fuel flow with super charging could be more difficult than with a NA motor and maybe more prone to problems.
Also, being at 4,500ft elevation is worth about a 13-14% power reduction (3% for every 1,000ft). So at your location, that 6psi boost would only put you at around 290hp.
To keep cylinder temps down I would definitely run a 160 deg stat and an intercooler.
I don't mean to lead you astray, but have always thought that at your elevation a super charger with a mild boost would compensate very nicely for the reduction in air density. Of course you need to do your homework so that there is no danger to the motor.
I'm going with a Carroll setup running 10psi water/alcohol inj, but, I 'm currently setting up the bottom end with a new chevy BowTie 4 bolt block, with 4340 forged rods and a 4340 Callies crank...for good measure! Crank has yet to arrive. Soon it will all come together. If your motor was an 85, I hear they come with forged pistons from the factory....go figure!
