Spark Plug Won't Go In
Old Oct 4, 2020 | 10:58 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
This stuff seems to be OK? Says "Suggested Applications: For easy removal of spark plugs, ...." Described as "A highly refined blend of aluminum, copper and graphite lubricants." No mention of avoiding aluminum and most likely they would say so if its use was limited.
Old Oct 4, 2020 | 06:10 PM
GregMartin's Avatar
GregMartin
Yes that’s the stuff I use too. It’s silver in color aluminum based with other elements like copper and graphite. The ones that are copper or brown in color are not suitable in this situation.
Old Oct 5, 2020 | 09:35 PM
9T3VETTE's Avatar
9T3VETTE
You dont need anti-seize on most modern spark plugs. The housings are plated with nickel or zinc coatings that will not corrode.
More likely to strip your heads with anti seize on the plugs than have them seize.
Old Oct 6, 2020 | 12:02 AM
aklim's Avatar
aklim
What would make it more likely to strip the heads? I mean, if you put them on a 3 foot pry bar and jumped on it, sure. Proper torque SHOULD be ok. I have had them come out hard and squeak without and not so much with anti seize so I am not clear how it is more likely to strip out the head.
Old Oct 6, 2020 | 06:01 AM
kenmohr's Avatar
kenmohr
I have heard the same from a GM tech.
Old Oct 6, 2020 | 06:33 AM
Joe C's Avatar
Joe C
my 2-cents...
one, looks to me the threads are boogered up. two, be careful using any kind of tap or thread chaser while the head is on the block. you really need to avoid getting anything inside the cylinder's combustion chamber. there are special tools for this type of repair - reference -https://www.amazon.com/Powerbuilt-640811-Back-Tap-Thread-Repair/dp/B0014FGVVW/ref=as_li_ss_tl?crid=686FEW2ZM296&keywor ds=powerbuilt+640811+back-tap+thread+repair+to&qid=1561747200&s=ga teway&sprefix=powerbilt+6408,aps,144&sr= 8-3&linkCode=sl1&tag=rideapart.com-20&linkId=f145c8c46cb8eaf04c68ffe4dc89a8 2f&language=en_US
for
anti-seize, most modern plugs do not require it, however I still use it. my preferred brand -
https://www.ebay.com/i/153938166996?...SABEgJKdPD_BwE
it the threads are truly cross threaded, you need to be extremely careful you get the repair tool straight and properly aligned - key word here is "CAREFUL" good luck with the repair - . try this for a little light reading - https://www.rideapart.com/articles/357239/ask-rideapart-crossthreaded-spark-plug/
whatever
you do, make sure it's expert approved!
Old Oct 6, 2020 | 08:02 AM
aklim's Avatar
aklim
Did he say why or was it just his belief? I have heard a lot of people complain that the factory plugs are hard to take out when they do the 100K service. They are stiff when removing, squeak like hell on the first few turns. A couple have broken off too. With these newer plugs, it is harder to check the plugs. I have personally gained a high of a mile and some change of gas mileage by just changing plugs when they are higher mileage like north of say 70 although the standard was 100K. I can't believe that it is perfect till 100K then falls apart. Only question I have is what the change interval should be before we lose too much gas mileage.
My usual treatment is changing them at 50K for a 100K plug with anti seize simply for ease of removal, more than anything else. On my turbo diesel MB, I used to take the glow plugs out once a year and bore brush the chamber and anti-seize the threads since I have had a couple of plug breaks. l Seems to work so I can remove it easily the next time instead of praying to the automotive gods for a no break removal when a plug went bad.
Old Oct 6, 2020 | 08:18 AM
Joe C's Avatar
Joe C
FWIW, just pulled the OE plugs on my son's 2011 camaro 3.6L V6 w/ 180K on the clock - plugs came out without problems - no real issues with the old plugs - very little noticeable improvement with new plugs. just saying....
Old Oct 6, 2020 | 08:24 AM
aklim's Avatar
aklim
Interesting to note. The used cars I have gotten have usually been stiff and squeak when the are turned. I get so nervous that it will break
Old Oct 6, 2020 | 09:28 AM
Joe C's Avatar
Joe C
just a side note, it is important to use a spark plug socket, and not a plain old socket when removing plugs. plug sockets are designed to grip the metal hex while isolating and cushioning the porcelain, thus minimizing the risk of breakage. I probably have over a half dozen specialty sockets (sizes, various lengths, built-in universals, etc.) just for plugs. most are six point, at least one 12. to date - knock on wood, haven't broken a plug yet.
Old Oct 6, 2020 | 09:35 AM
aklim's Avatar
aklim
just a side note, it is important to use a spark plug socket, and not a plain old socket when removing plugs. plug sockets are designed to grip the metal hex while isolating and cushioning the porcelain, thus minimizing the risk of breakage. I probably have over a half dozen specialty sockets (sizes, various lengths, built-in universals, etc.) just for plugs. most are six point, couple 12's. to date - knock on wood, haven't broken a plug yet.
I don't have that. I have a wobble and straight plug socket is all. Maybe someday, if I need them, I will. I just hate to be buying one off tools.
Old Oct 6, 2020 | 11:10 AM
9T3VETTE's Avatar
9T3VETTE
Anti-seize changes torque values (ie. friction), therefore its much easier to over-torque. This could strip aluminum heads if torqued too much, but can also stretch the plug housing. In the later case, the internal crimp/seal inside the plug could be damaged resulting in internal combustion leakage.
Old Oct 6, 2020 | 11:17 AM
  #33
aklim's Avatar
aklim
IIRC, for "wet" torque values, you drop the number by 10 or 15 percent? My lug nuts or bolts would be at 85 in the spec calls for 100 simply because I have salty roads and wanted to get them out easily when I needed to.
Old Oct 6, 2020 | 11:22 AM
  #34
Joe C's Avatar
Joe C
have many "one-off" tools. one of my many bad habits - i'm a tool junkie. personally, been collecting for 50+ years -- inherited my dad's set, and he inherited his dads. i'm sure my tool collection goes back, well over 100 years.
Old Oct 6, 2020 | 03:07 PM
  #35
9T3VETTE's Avatar
9T3VETTE
Absolutely you could do that. General rule of thumb with spark plug is 20%. Most people are not smart enough to consider that, they lube em' up and give it the old un-calibrated forearm wrench. That's when problems happen.
Old Oct 6, 2020 | 05:22 PM
  #36
aklim's Avatar
aklim
So in this case, the lack of lube is a buffer for stupidity? Fair enough. I really don't like to use German torque techniques, Guten Tite.
Old Oct 6, 2020 | 05:40 PM
  #37
9T3VETTE's Avatar
9T3VETTE
LOL.
yea that’s one way to look at it. The other is Ni/Zn plating on the housing will prevent seizing. Brazil market vehicles that run E100 through their plug service intervals don’t even use anti seize.
To Spark Plug Won't Go In
Old Oct 7, 2020 | 08:36 AM
  #38
kenmohr's Avatar
kenmohr
He said it will help them to bond. Recommend to just lube with synthetic oil.
Old Oct 8, 2020 | 05:57 PM
  #39
Railroadman
To me, the biggest obstacle is trying to torque them with all the assorted braces, brackets, pipes etc. Can't get the wrench on them, or can't swing the wrench enough to get more than a click at a time. A universal is SOME help, but not always. Not to mention the notorious #8!
Old Oct 8, 2020 | 06:08 PM
  #40
ChumpVette's Avatar
ChumpVette
You just have to get rid of all the excess garbage.
