Crossfire dead spot
So...I'm THINKING that the TPS is not set right?? The sensor looks new and I see that it has some adjustment in its angle.
Thanks for reading.
Thanks for reading.
And yes, the engine has different heads, cam, exhaust. We arrived at 15 PSI by reading the plugs. At 13 a bit white....now nice and brown.
The reason I asked about your motor is that 15 is usually too high for a stock motor, but since it is NOT stock, 15 probably works OK. What ECM are you using, what heads and what cam and lastly what intake? Curious, and have to put it on a dyno with what results?
Stock ECM: is a chip worth anything in these cars?? Or should I just junk it and get something smarter?
Stock intake....kinda I had a buddy port it out for some more flow, Ive been eyeballing the renegade intake, but most of my team mates want me to drop a 650 Holley on it and call it done. Thoughts??
Cam: Edelbrock Part # 3702 Performer-Plus camshaft with crane 1.6 roller rockers
Heads: Chevy Vortec heads. How did I manage that?? little magic and a little carbide ;-)
A stock ECM will only go so far and not a fan of chips since the 82 ECM was never completely hacked like the 84 was. You will have to replace it if you want more power so you can dial it in better. The BEST thing going IMO is from Dynamic EFI and moving to the EBL Flash II ECM and HAM board from me. It is by far the best thing going unless you want to move to something like a Haltech and then you would have state of the art control, but you WILL have to re-pin your entire harness, hope you get it right and replace the connectors, that would be up to you. If I ever decide to replace my current EBL which works fine, I will switch over to Haltech next.
On the intake, since there are no Renegades available that I know of, porting does work, but just be careful not to bust through into the water jacket, those walls are not that thick, but we did make the Renegade with a bit thicker walls for just that task. Ahhh...Vortec heads, there's a fine subject to talk about maybe for another time. Will it work, yes. Do I recommend it to anyone, no. You can make it work, but it is a lot of work and a bit dicey IMO. We did that project more than a decade ago and it did work, but I didn't trust it at all and soon was removed. I would have just went to something else like a 175/180 head and just bolt it on. A Vortec head is a good head though.
