Confused on wheel alignment
Old Oct 18, 2020 | 06:43 PM
Mason8383's Avatar
Mason8383
Default Confused on wheel alignment
Hi there,
I have a 1994 Vette that I have been daily driving for a while now. No issues whatsoever with only 112 k miles on the odometer. I just started replacing the rotors and brake pads on my car yesterday and just started on the rear today. Well all I've done was raise the rear wheel up on a jack and then lower it back down and now it has a severe positive camber, definitely looks messed up. Is there anything or any solution to fix this? Any help would be appreciated. Just to clarify i have looked for bent or damaged parts and can't visibly see any
Old Oct 18, 2020 | 07:06 PM
84 4+3's Avatar
84 4+3
Originally Posted by Mason8383
Hi there,
If you haven't driven it or moved it at all, do that. Mine looks weird after jacking until it rolls a bit.. because it moves so much with compression changes it doesn't come back down correctly.
Old Oct 18, 2020 | 11:27 PM
MatthewMiller's Avatar
MatthewMiller
Yep, the suspension links move in arcs, and when you set it down the rear tire comes down on the inside of its arc. Once it's off the jack all the way, this will keep that corner jacked up and with positive camber until you move the car. IOW, don't worry about it.
Old Oct 19, 2020 | 09:35 AM
radar502's Avatar
radar502
Yep drive it around the block it will be fine ...
Old Oct 21, 2020 | 09:47 PM
Maxbass65's Avatar
Maxbass65
Hello, I saw where you are changing the brake pads and rotors on your 1994. I also have a 1994 and am wondering which brake pads and rotors you decided to go with?
Old Oct 30, 2020 | 08:59 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Method I use to keep the rear from "squatting" so bad is lower the rear on folded trash bags, the slick ones.
Make sure you're on a level surface and block the fronts, of course! And side jack!
Old Oct 31, 2020 | 12:17 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
While a clever idea....you still need to roll the car one direction, then the other to get the trash bags out from under the car. That same action will allow the tires to settle down into a normal position anyway, so....extra work and a waste of two trash bags.
Old Oct 31, 2020 | 12:32 AM
84 4+3's Avatar
84 4+3
I kind of like it. Like reverse stance yo.
Old Oct 31, 2020 | 03:03 PM
MatthewMiller
Where the trash bag idea actually comes in handy is when doing one's own alignment at home.
Old Oct 31, 2020 | 03:18 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Indeed. Great adaptation of a great idea!
Old Nov 2, 2020 | 03:24 PM
kael's Avatar
kael
Meh. I manually move Her two feet to remove the bags, don't even start. And can certainly use the bags more than once!
Psst, moving a car, on a level surface of course, is a lot easier by rotating the tires instead of pushing. Little thing called torque.
To Confused on wheel alignment
