o2 Problem
Old Nov 11, 2023 | 02:47 PM
Jo bar's Avatar
Jo bar
I have the same problem but with the right sensor I can't find the solution, could it damage the engine?
Old Nov 11, 2023 | 02:52 PM
Jo bar's Avatar
Jo bar
Old Nov 11, 2023 | 04:18 PM
Livewild's Avatar
Livewild
Depends, the misfire I was having wouldn’t change regardless of what I changed which lead me to believe it was an engine problem, engine codes and sensor readings are a completely different situation. I’d need a little more specific’s to help ya out
Old Nov 12, 2023 | 12:59 AM
Jo bar's Avatar
Jo bar
it all started like this while I was running in the street the SES light comes on and the radiator fans together I immediately go back home the engine stops but I manage to get to my garage I notice that when I tap my hand on the ECM the engine stops, I have it rebuilt when I put it back on the car I start the engine and the engine rpm are high in parking 1500, I try to run on the road and the SES light comes on, in parking the engine always runs at 1500 rpm, I read the codes h64 and h62 my thoughts is that now the Ecm is ok it sees the engine errors then I replace both the o2 and iac sensors but the situation does not change with the engine hot in park always 1500rpm and engine light i no long see the code h62 but only h64 module 4I clean all the ground masses but I don't have a scanner what can I do?
Old Nov 12, 2023 | 01:02 AM
Jo bar's Avatar
Jo bar
I hope I wrote correctly
Old Nov 12, 2023 | 06:53 AM
arbee's Avatar
arbee
Hard to say. I have given up trying to read these one line word salads. Try some punctuation and proper sentence structure and I am sure you get more responses.
Old Nov 12, 2023 | 02:10 PM
Livewild's Avatar
Livewild
From what I remember I had a similar issue, when I had a hard ecm fault(example- messing with the tune improperly) it would kick both fans on ignition as well as idle at 1500. It’s like a fail safe limp mode. First thing I would do is reset everything, disconnect both battery terminals turn on the headlights as well as honk the horn and hit the brake pedal a few times get rid of all power that’s stored and let it sit for a few minutes. As far as tapping the ecm it definitely sounds like there is some fault going on inside. A loose or broken pin. You can disconnect the main harness and inspect the plugs and pins ecm side.
Old Nov 12, 2023 | 04:51 PM
Jo bar's Avatar
Jo bar
the ECM has already been repaired, but the problem of the high idle and the SES light is back, and I extract the h64 code
Old Nov 13, 2023 | 01:41 PM
Livewild's Avatar
Livewild
[QUOTE=Jo bar;1607232052]the ECM has already been repaired, but the problem of the high idle and the SES light is back, and I extract the h64 code[/QUOTE
all I could recommend is a hard reset with the battery disconnect. A bad O2 sensor in my case, didn’t cause a high idle and check engine light so there’s most likely something else going on. And the tapping on the ECM definitely should not happen. Make sure it’s fully seated and plugged in properly. Check the pins and plug. After that, I would check the resistance between the O2 sensor and the pin on the main harness. The H64 code is a common one from what I remember. I’m sure there’s someone with a similar situation that has found a solution. I check out more recent threads with a more similar issue for a solution, best of luck
Old Nov 14, 2023 | 07:00 AM
Jo bar's Avatar
Jo bar
Ok have a good day
