1994 Headlight Issue
Old Nov 9, 2020 | 05:39 PM
TorchTarga94's Avatar
TorchTarga94
Default 1994 Headlight Issue
Both headlights flip up no problem with the headlight switch except the headlights themselves do not turn on. I've checked fuses and fusible links and all seem okay. Has this happened to anyone else? Can you point me in the right direction? All other exterior lights work correctly, even the fogs.
Old Nov 9, 2020 | 06:48 PM
Nomake Wan's Avatar
Nomake Wan
First thing to do is make sure there's actually power and ground going to the headlight harnesses. In addition, while the lights are flipped open, can you turn the high beams on?
Time to unplug one of the lights and confirm you actually have power. If you don't have power, time to trace the wiring back to find out why.
Old Nov 10, 2020 | 04:34 AM
TorchTarga94
I appreciate the reply! I found my problem. Apparently a few months ago when I was cleaning/adjusting the brake/cruise switches I must have disconnected the headlight switch at base of column . All good now!
To 1994 Headlight Issue
