Storage additives?
Old Nov 27, 2020 | 12:32 PM
Beardeddan's Avatar
Beardeddan
7th Gear
Default Storage additives?
I'm putting my 91 into a winter storage facility for 4 months. It's heated and will have a battery tender. Are there any additives I should put in the gas when storing for that length of time?
Old Nov 27, 2020 | 01:15 PM
Hawkeye56's Avatar
Hawkeye56
This year I am leaving about a 1/4 tank of gas, This is from a article in the Corvette magazine that a full tank covering the fuel sender will be harmed due to chemicals in the fuel. I did add St Bil for fuel preservation.
Thanks Hawkeye56
Old Nov 27, 2020 | 01:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
Never add a thing, my a body sits for 6 months to a year sometimes. Charge the battery and turn the key thats it.
Old Nov 27, 2020 | 03:12 PM
Tcapper's Avatar
Tcapper
I have never added any additives to my fuel. the shop is only heated when I need heat and I've stored my '81 Trans Am and my '84 Mustang GT Vert which are both sold, the '87 Vert is in the same shop and as cv67 said charge the battery and it starts.Although I use battery tenders and premium fuel, but it's up to you.
Old Nov 27, 2020 | 03:21 PM
Mrvettenick's Avatar
Mrvettenick
Not a big fan of any additives.
Old Nov 27, 2020 | 11:04 PM
jv9999's Avatar
jv9999
I always use Stabil in all my seasonal gas engines. We can only get E10 here in the northeast and it goes bad really quickly. You can probably get away without it, but why risk it?
Old Nov 28, 2020 | 08:11 AM
Whaleman's Avatar
Whaleman
I dump in an old fashioned bottle of HEET to eat up any water that may condense. Dan
Old Nov 28, 2020 | 08:23 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Thanks Hawkeye56
It could rust too by not being covered. Terrible advice
Old Nov 28, 2020 | 08:49 AM
SJW's Avatar
SJW
I've left my C4s, and several other vehicles, sitting all winter for years. Sometimes as long as 6 or 7 months. Zero additives, battery tenders on, and zero issues as a result. Never, ever, been a problem. Tires flat-spot, but after a couple miles of driving, they're round again.
Small carbureted engines are a different matter. I always run them completely out of fuel before storing for more than a month. I've had to clean out more small carburetors than I could count after the ethanol-laced fuel jelled in their tiny jets.
Live well,
SJW
Old Nov 28, 2020 | 09:07 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Thanks Hawkeye56
My thoughts exactly. I can't tell you how many rusted sending units I've come across in super clean cars that you would never guess would have that issue.
You also have the consideration of the volitiles evaporating from the gas which will result in the gas going "stale" much faster with a 1/4 tank than with a full tank.
Keep the tank full, no additives, and you will be just fine in the spring.
Old Nov 28, 2020 | 09:08 AM
84 4+3's Avatar
84 4+3
Fill the tank and throw on a battery tender. Otherwise I would not worry about it.
Old Nov 28, 2020 | 09:31 AM
Hawkeye56's Avatar
Hawkeye56
Bad Advice
Check out Tech Nerd in the June 2020 Corvette Magazine, Filler Partially up
or check with GM on 2003 and later they have changed their stance on storage with a full tank.
I was agreement with you until I read the article.
Thanks Hawkeye56
Old Nov 28, 2020 | 09:46 AM
aklim's Avatar
aklim
Thanks Hawkeye56
So how does that work? When I fill up, I run a full tank and that would be the same thing.
Old Nov 28, 2020 | 10:00 AM
Hawkeye56's Avatar
Hawkeye56
From the article
Fuel that sits in the tank all winter will damage the fuel sender card from the sulfur.The reason it targets 03 and newer is the tank has to be dropped to repair. We all know the C4 does not. I suggest you look up the article and make your own decision.
Old Nov 28, 2020 | 10:19 AM
RUU's Avatar
RUU
From the article
C5 and newer tanks are made of plastic and won't rust from being exposed to humidity inside the tank. Not applicable to C4s or any vehicle with metal gas tanks.
Old Nov 28, 2020 | 10:22 AM
markKlein's Avatar
markKlein
Bad Advice
Thanks Hawkeye56
I read that too, but wasn't that for 2003 and up models? Not C4s?
Old Nov 28, 2020 | 10:28 AM
Hawkeye56's Avatar
Hawkeye56
A very good point.
Then we will have to decide what will cause the most damage in your tank rust or sulfur.
With this being pointed out I personally think rust is the worst. I will replace my sender assembly a lot easier than a rusty tank and what else the rust infects.
Thanks Hawkeye56
To Storage additives?
Old Nov 28, 2020 | 10:44 AM
aklim's Avatar
aklim
From the article
Got a link?
Like I said, I'm curious how it doesn't damage the sender card when you have fuel in it for normal use.
Old Nov 28, 2020 | 10:50 AM
Hawkeye56's Avatar
Hawkeye56
Got a link?
This is the article I am referring to.
Thanks Hawkeye56
Old Nov 28, 2020 | 11:00 AM
jv9999's Avatar
jv9999
Heet is methanol. The "10" in E10. The absorption of water is what makes it corrosive.
