ABS delete 10mm bubble tee
Old Nov 27, 2020 | 02:56 PM
project C4's Avatar
project C4
Default ABS delete 10mm bubble tee
Quick question to the experts on the subject. I know I need at least one of these 10mm tees to join the front lines. Are the two rear lines the same 10mm tee with a plug in one of the ports on the tee ?
Old Nov 27, 2020 | 07:38 PM
Aardwolf's Avatar
Aardwolf
There is some info in my old removing ABS thread:
https://www.corvetteforum.com/forums...bs-thread.html
Old Nov 28, 2020 | 12:57 AM
project C4's Avatar
project C4
I had seen and read that one before and somehow missed the two like tees part. Thank you sir. seems easy enough
Old Nov 28, 2020 | 10:35 AM
Aardwolf's Avatar
Aardwolf
No problem! I was surprised the apple tree link is still valid for buying the tee.
Old Nov 29, 2020 | 07:08 PM
joeld's Avatar
joeld
After reading thru this post, it looks like all that is required to eliminate the ABS system is using the 3 way T-fitting to connect the lines for the front brakes and another T-fitting to connect the rear brakes?
Joel
Old Nov 30, 2020 | 05:13 AM
project C4's Avatar
project C4
Joel
Yes or you can just use a union for the two rear brake lines. If you use the tee for the rear you have to plug one of the holes
Old Nov 30, 2020 | 09:46 AM
joeld's Avatar
joeld
Thanks for the reply.
Joel
To ABS delete 10mm bubble tee
