LT1 Block options
Old Dec 19, 2020 | 09:44 AM
krusher998's Avatar
krusher998
Cruising
Default LT1 Block options
I have a 95 corvette with the LT1 motor and I want to work the bottom end. I wanted to know can I use a 383 Block and use all my aftermarket top end. Currently have Trick flow heads, Edelbrock intake and BBK throttle body. If there is a better option please help. My budget is going to be between 5 - 7K
Old Dec 19, 2020 | 11:03 AM
cv67's Avatar
cv67
St. Jude Donor '05
Your 350 turns into a 383 when you put the crank kit in. 3.75 stroke instead of the stock 3.48
You can do a 390 or even 409 too with what you have.
Golen may still sell these? Only thing I dont like about mail order is if theres a problem you have to count on them backing it up, shipping cost etc.
page tpi421vette, thread starter...some good reading. Driveable and chitloads of power
https://www.corvetteforum.com/forums...ine-build.html
https://www.corvetteforum.com/forums...-pictures.html
Old Dec 19, 2020 | 12:21 PM
krusher998's Avatar
krusher998
Cruising
Can i get a 383 from like jegs or would it be better to do it with the cast iron block i have now?
Old Dec 19, 2020 | 05:41 PM
C409's Avatar
C409
..... It will only work if its an LT1 based short block ... a 383 is a little more than just dropping in a crank , some rod clearancing is needed at the oil pan rails for the connecting rods .....
To LT1 Block options
