AIR Pump Eliminator
Old Dec 7, 2002 | 05:26 PM
montecarlo4's Avatar
montecarlo4
Default AIR Pump Eliminator
Hey Guys
Need some advice, took off my old AIR Pump on my 84 and put the Eliminator part on and not sure how to run my power steering resovior. Any suggestions or how did you do it?
Thanks matt
Old Dec 7, 2002 | 07:57 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: AIR Pump Eliminator (montecarlo4)
When you get a chance, call Breathless Performance at (954) 925-7725 and just ask them. They're fairly cool bunch of guys. My brother had bought the AIR eliminator from them and the owner actually took the order and took time to explain the setup to my bro. Good luck! :cheers:
Old Dec 7, 2002 | 08:07 PM
montecarlo4
Default Re: AIR Pump Eliminator (CoolVette86)
Alright I will do that, i assume they wont be open till Monday, so i will give it a go than, i was just hoping to finish 2nite or early tomorrow to go try it out.
matt
Old Dec 7, 2002 | 08:51 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Can you even use the Breathless air pump eliminator on an 84?
I thought you just used a shorter belt and the accessory drives were different.
Old Dec 10, 2002 | 04:04 PM
montecarlo4
Default Re: AIR Pump Eliminator (Red 90 L98 Coupe)
It said 84 in the magazine and on the Forum where I ordered it. But I imagine it would have been easier to just use a shorter belt. Anybody know the size to change it too.
matt
Old Dec 11, 2002 | 08:20 PM
The Dingo's Avatar
The Dingo
I can't tell you what belt to use but I recall having read something about it here before.
Maybe you could try searching under air pump or some variation in C4 Tech... Sorry but that is the best I can do.
Anyone out there know the correct belt offhand?
[Modified by Red 90 L98 Coupe, 11:22 AM 12/12/2002]
To AIR Pump Eliminator
