Different engine swap question
Old Jan 8, 2021 | 10:10 PM
M1917's Avatar
M1917
Default Different engine swap question
Hello
I have a question I don't think has been asked before. I'd like to upgrade my c4 with a better performing small block. I understand the TPI system is a cork. In theory, if I had better heads and an aftermarket injection like a a stealth ram, or the system that TPIS sells can the stock computer run it? If not, can an aftermarket system be integrated in my car so I have functional gauges?
I had an LS in my TA, it was awesome. But, I have a 6 speed. I have no desire to replace the entire drive train on the car. I have no illusions about keeping up with a modern car. Just would like to avoid being embarrassed by the wife's Flex with the 3.5 turbo motor.
Be gentle guys. It was just a question...
Old Jan 8, 2021 | 11:09 PM
aklim's Avatar
aklim
Originally Posted by M1917
Hello
Stealth Ram means you have to cut a hole in the hood. You game? As far as running it goes, what is your definition of "running"? I had some hesitation at WOT with a set of Accel Tri-Y headers and the Superram on a stock L98. Brought it to Lingenfelter and he reprogrammed the thing and it was gone. It worked but not good enough for my liking. So if you are finicky, it might not work. You might be able to get away with it for a while until you decide to let someone update the program to reflect the changes.
Old Jan 9, 2021 | 11:14 AM
Kevova's Avatar
Kevova
If this is an automatic rear gear change will do more to prevent embarrassment than engine work.
Old Jan 9, 2021 | 11:35 AM
aklim's Avatar
aklim
Not sure what to do. If he wants more power, would a gear change on a D36 be worth it? Or maybe bite the bullet and get a D44 with the right gear and swap it when time and money permits?
Old Jan 9, 2021 | 12:05 PM
Kevova's Avatar
Kevova
If it's an auto with a 2.59 it would. 3.07. Widely available and sometimes inexpensive.The 84 only used a D36 and had an optional 3.31. 84 batwing does use different camber arm bracket bolts, so it's not necessary. A gear change in a D36 will be close in cost to a D44 change over. I would look for a 3.45 or 3.54 for just a bolt in swap.
Old Jan 9, 2021 | 12:43 PM
M1917's Avatar
M1917
That's helpful. I was not aware of the tuning issues. The car is a 6 speed. I have the sticker someplace. I believe it's the performance rear gear.
Let me ask the question differently. Is there a small block combo that works? I want it to idle and be driveable. I was into these things when they were new. I know the TPI system is a major limitation. Is there an aftermarket injection that works well? Or, for the folks that went down this route the last 25 years found that the combo tops out at a certain number and anything after that requires a LS etc. swap? It will need to be NA. Zero desire for a blower or turbo.
Old Jan 9, 2021 | 02:49 PM
JoBy's Avatar
JoBy
What year do you have?
At least if you have the early digital dash it will still work if even if you install another ECM. The only things you loose are instant MPG, average MPG and range on remaining fuel. That is because fuel usage information come from the ECM. All other sensors on the dash, and also cruise control that is a part of the digital dash will continue to work. Sensors like coolant are duplicated, one for ECM and one for the dash.
Old Jan 9, 2021 | 03:05 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
What I would do,
-Mini ram, or modified LT1 intake.
-Heads ported, or better flowing aftermarket heads.
-Injectors
-Hot cam, comp 503, or similar cam kit.
-1.6 roller rockers.
-Headers.
-True dual exhaust.
-Tune
or find a C5 Z06, the price is getting very reasonable now days.
Old Jan 9, 2021 | 03:52 PM
aklim's Avatar
aklim
Originally Posted by James93LT1
What I would do,
-Injectors
-Headers.
-True dual exhaust.
-Tune
If you are going to get a dyno tune, why not use a better cam than that? Maybe a custom ground one that the Tuner likes?
Or better yet, Z06 or maybe a C6 even?
Old Jan 9, 2021 | 05:41 PM
Kevova's Avatar
Kevova
You are really getting into budget thing. There lots of sbc builds. Trying to make it work with factory efi can get expensive. I would go with a mild 400 sbc build.
Old Jan 10, 2021 | 09:42 AM
aklim's Avatar
aklim
Let's talk money since that dictates your project. Fast, Reliable, Cheap. Pick any 2.The money will dictate what you can do. What are your plans for this car? Is it a keeper or just something to play with? Can you do most of the work or do you need to farm it out?
As to tuning, here is my take on it. If you are going to get the setup, I'm not sure it is a good idea to "Frankenstein" the thing. I would consult a person who could tune and set up the build combo. It should all work well together with your goals. You are building a system so they all need to work well together or you may not get the "bang for the buck". I would go for a Superram or Miniram since the ACCEL and TPIS have laid out the combo if you don't want to find a builder for suggestions. The computer can run those systems and just needs to change the programming. Once you get more radical than headers, intake and fluffed heads, you are looking at transmission and rear end.
Old Jan 10, 2021 | 10:07 AM
bjankuski's Avatar
bjankuski
Hello
Short answer is yes the stock computer can be programmed to run a sbc with any of the combinations you are discussing. Mild sbc with a mini ram works great.
Old Jan 10, 2021 | 10:22 AM
M1917's Avatar
M1917
Thanks guys. Good advice on this board. In short, the car is a 90 6 speed convertible. It's triple black. I bought it 2 years ago. I'm planning on keeping it. The year is significant for me. I taught my son how to drive a manual with this car and plan to do the same with my daughter when she gets her license. I work for a living and have college and retirement to think about so I have a small budget. But, a little at a time will work for me. Thanks again for the guidance
Old Jan 10, 2021 | 11:04 AM
aklim's Avatar
aklim
Headers will be a grand or north of it for ceramic coated headers. I prefer TPIS because they are bolt on without having to fabricate stuff for the brackets and supports. Another grand or so for the intakes. With tuning on a dyno and misc stuff, let's call it 3 grand.
Old Jan 10, 2021 | 12:31 PM
M1917's Avatar
M1917
One more add on to my question. Do I need to have it tuned if I install only headers?
Thinking about approaching this in steps
Old Jan 10, 2021 | 01:40 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No.
Old Jan 10, 2021 | 02:16 PM
aklim's Avatar
aklim
I'd want to do it after heads and intake but you can just do headers and forget it.
To Different engine swap question
