Roller lifter failure causee loud tapping noise or wipes lobe off cam. You could try to power balance by disconnecting injectors to see if there is a weak cylinder. You numbers really don't indicate a obvious problem. Why do you feel you're down on power? ET, dyno, lap times?
Track and dyno. Put 315 to the ground when first built.. im at ~255 now.
Also, all fuel injectors have recently been serviced and have flow reports for.
Plugs have been changed. No cats,, deleted from ECU. Im going to take it in for a tune and see what I get. Also going to install some widebands before hand..
Funny, I've got the opposite problem. I was showing somewhere around 200psi cranking compression (if memory serves), but leakdown tests were really abysmal. I recall it reading 50% or higher leakdown. I'm ~75% sure the issue was just a low-quality leakdown tester, as I noticed results varying dramatically depending on the supply pressure. I suggest making sure you can trust the results from the leakdown and compression tests you did. I'm interested what you find.
Couple thoughts.. worn timing chain/gears could be retarding cam timing. And excess lifter and or their bore wear could be decreasing lift. That COULD be losing lift, so when trying to take a "gulp" of air during compression test you're basically losing .035" or so of valve lift. Basically sounds like she's"tired" ready to be freshened up.
