LT1 383 Stroker engine specs
Old Feb 15, 2021 | 06:14 PM
Michael.parker1's Avatar
Michael.parker1
Default LT1 383 Stroker engine specs
In the process of building my 383 stroker and I’ve got some questions about engine specs. I pretty much know all my torque specs for bolts and stuff but mostly needing clearance specs. Should I be using stock LT1 specs for stuff like bearing clearances and thrust specs and stuff like that or is there a thread someone can direct me to that may have already gone over this? Unfortunately I can’t find much. Mostly in need of bearing clearance numbers as well as what I should be clearancing from between my rods and block. I’ve done first assembly on the engine just to see how close my rods are to the block and I have 0 actual interference but they are a little closer than I’d want. I have not actually measured the exact clearance between them but I will once I get some more time to work on the engine more and try to post an update on it. Also what is the best way to install the crank gear for the timing set? Is it best to heat it up or what? Mine won’t slide far back enough and I also need to get a new key because I cannot find the one I had for it now. Thanks in advance for the help.
Old Feb 15, 2021 | 06:59 PM
84 4+3's Avatar
84 4+3
Specs are specs. The factory manual is what I would go by unless the components you are using say otherwise. For example ring gap. Anything I've done I've gone with factory spec (granted it was all gen 1) but it didn't let loose. It was on the tight side however.
I'm not super familiar with the crank setup on the LTs but any 350 I've just heated and used a dead blow hammer on a pvc or copper pipe. Worked fine. You don't want to hammer the thrust bearing. (Not ideal I know but it's what I had)
Old Feb 15, 2021 | 07:05 PM
Michael.parker1
I have ring gap specs from the manufacturer that I got the pistons and rings from I just don’t have anything for stuff like bearing clearances and stuff like that, thanks for the help I’ll try the heat and PVC or copper pipe.
Old Feb 16, 2021 | 03:53 PM
rklessdriver's Avatar
rklessdriver
Bearing clearance in high performance engines are pretty universal.
.001 per inch of journal diameter is a good rule to follow.
In the case of your 383 .0021 rod and. 0025 mains would be good target clearances. Thrush clearance or crankshaft end play should be in between .005 and .008.
Will
To LT1 383 Stroker engine specs
