C4 optispark system
Old Mar 7, 2021 | 10:23 AM
SJW's Avatar
SJW
I recall more than one thread on this forum about quality problems with the Dynaspark product after DTE sold that business off to a different party. Seems the buyer of the business was unable to keep the business afloat, which is really sad. It was a quality product while DTE was still building and selling them. Billet aluminum housing, active venting, etc. Timing is everything in life (no pun intended) and I got lucky by needing one while it was still a product of DTE.
Live well,
SJW
Old Mar 10, 2021 | 03:58 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Originally Posted by tblu92
The early Optispark ignition systems were all prone to failure-That is why GM discontinued them soon after--They all get water intrusion into the cap from either rain or coolant leaks-Your best bet is to install an aftermarket MSD ignition system that is far better sealed--and not that pricey No problems ever again
No, it isn't. The MSD has a habit of failing due to a cheaper sensor used.
The unit may well be sealed, but that was never the issue in the first place.
Replacing the cap and rotor is ALL that is needed on a working distributor, you can use a Petris or an MSD cap and rotor kit, results will be the same.
I am quite impressed with the Petris. It is cheaper than the MSD, and i reckon it is better too.
The best distributor is the original GM unit, mine is still fine at 28 years old.
Old Apr 9, 2021 | 01:44 AM
ME93's Avatar
ME93
new guy here, does a new optispark need to be disassembled to install or just throw it on from the box ? how do you seal the new optispark? thanks.
Old Apr 9, 2021 | 12:15 PM
Kevova's Avatar
Kevova
No disassembly required. Make sure seals on timing cover or in good condition or replace. Properly orientate drive on either cam (95-96) ir on splines, (92-94) one tooth is missing. Don't force it on spline type. It should just slide on flush.
Old Apr 9, 2021 | 02:32 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yes. You should take the cap off, remove the rotor's screws, apply Loc-Tite to them, and re-assemble.
Old Apr 9, 2021 | 04:41 PM
ME93's Avatar
ME93
Do we need to seal optispark? Or just put a weephole spout hose redirect on waterpump ?
Old Apr 9, 2021 | 06:30 PM
Nomake Wan's Avatar
Nomake Wan
No need to do that if you buy one from Petris or optisparksolutions. Dunno about Sac City.
Old Apr 9, 2021 | 06:45 PM
SouthernSon's Avatar
SouthernSon
If anyone hears anything negative about Petris Opti's I would like to hear it. I have been quite satisfied with mine for quite awhile. The previous 3 from other makers not so much. Petris solved my opti problems.
