C4 Death Trap
Old Mar 2, 2021 | 08:26 PM
jmgtp's Avatar
jmgtp
Forget the code reader and invest in a quality aldl to usb cable. Some free software and you will be miles ahead on valuable real-time data.
Old Mar 2, 2021 | 08:31 PM
Mason8383's Avatar
Mason8383
Should I log all my previous history codes, reset them, and then see which one reoccurs? I feel it would be a much faster process.
Old Mar 2, 2021 | 09:07 PM
aklim's Avatar
aklim
Android or fruit phone? If android, maybe THIS might help? It scans data and is easy to use. At least, it is for my 91.
Old Mar 2, 2021 | 09:53 PM
Mason8383's Avatar
Mason8383
So I reset all my module codes, let my car run till it died out again, and rechecked the code list.
As follows
Module 1:
C31
C33
C35
C37
Module 4.0
Module 9.0
H64
Any thoughts?
I believe the CCM Module 1 codes arent indicating anything since before I reset them they were fine. It might just be from a weak battery. However, if im not mistaken, I think H64 indicates lean 02 sensor, correct?
Old Mar 2, 2021 | 10:59 PM
Mason8383's Avatar
Mason8383
So after the reset, my car shut off in park after I slightly gave it gas. It showed H64. Now, I restarted the car and it wouldn't shut off at all. I even took it around the block for around 10 mins and hit a few hole punches. It will not turn off. Is there any way the o2 sensors can act up and run normally again? Also, my car runs really rich, so im leaning toward o2s.
Old Mar 2, 2021 | 11:41 PM
aklim's Avatar
aklim
If the O2 is more than 5 years old or 50K, I probably will toss them. How ever many there are, toss them all. Still, I don't believe a faulty O2 can do what you say happened.
Old Mar 2, 2021 | 11:46 PM
Mason8383's Avatar
Mason8383
I think they may be original 02s, my 94 has a114k miles on it, only the 2nd owner. If not the 02s, could it then move to the fuel system? It idles fine and doesn't stumble, but once it gets a little gas or at idle, it shuts off.
Old Mar 2, 2021 | 11:55 PM
aklim's Avatar
aklim
I'd definitely toss the O2 especially in the upstream part. People usually ASSume that the O2 is good till it fails. I believe they get old and lazy before they fail usually. That messes up your mileage, at least.
Could what move to the fuel system? As to it idling fine, I really don't know what that means. If it is a SOTP dyno thing, I'd definitely be more suspicious. IMO, the cars are much better at hiding things by making adjustments than they used to be so it is harder to spot an issue. If you mean it idles fine by reading the data from a scanner, that might be another issue.
Old Mar 3, 2021 | 12:12 AM
Mason8383's Avatar
Mason8383
I see what you mean about the 02s, ill get them replaced. When I said move up to the fuel system, I meant can the o2 sensors code that popped up also include fuel system failures? When I mean it idles fine, it starts up without hesitation, sits at a steady rpm, and does not become sluggish at a stop or when I take off. Nothing indicated bad air or fuel ratio to me, aside from the fact that it runs rich.
Old Mar 3, 2021 | 12:21 AM
aklim's Avatar
aklim
I don't know how it would do that. I mean, if the injectors pulse but the pintle is clogged or something, it might not show up as anything. My car ran relatively smooth. I sent the injectors to be serviced. They were all of different values before and one of them was way off because the basket filter somehow collapsed. IIRC, that was one of the batches I verified before sending them off and after getting them back to make sure the shop (FIC) was doing what they said.
Old Mar 3, 2021 | 12:29 AM
Nomake Wan's Avatar
Nomake Wan
That is true, and I will order that code reader. However. I did short pin 4 and 12 and found my code reads on the gauge panel which goes as follows:
Module 1:
C12
Module 9:
H64
H72
H73
Module A:
C51
C52
H24
H42
H51
H52
H61
H62
H71
H76
If anyone can help point me in the right direction about these I'd appreciate it. I can go down the list to figure them out, but if anyone has some knowledge on this it wouldn't hurt while I'm doing it.
Module 1 is the CCM and indicates no codes. Module 9 is the ABS/ASR and indicates TPS signal failure, serial link data fault, and spark retard monitoring fault. Where is Module 4?
Originally Posted by Nomake Wan
Since it's a 94, if you want to DIY, you could always try datalogging from it using a laptop, see if you can capture data from the car when it dies to see what exactly is dying. If you want to explore that option, here's the cable you'll want to grab: http://aldlcable.com/products/aldlobd2u.asp
And here's the software (free): http://fbodytech.com/eehack-2/download-eehack/
As stated multiple times, this USB cable with a laptop is far superior than any standalone scan tool or cell phone for a 94-95 Corvette.
Also a failing O2 or coolant temp sensor won't kill the car. It could make the car run poorly, but it won't completely kill it.
As follows
Module 1:
C31
C33
C35
C37
Module 4.0
Module 9.0
H64
Any thoughts?
Incorrect. Module 9 H64 is "ABS/ASR TPS signal failure." Your new CCM failures are very peculiuar. Either they're CCM internal failures or you have some bad mojo going on inside the dash. I wonder if it had to do with your airbag system having deployed at some point (according to the codes you had before you erased them).
The discrepancy in codes seems to indicate some serious electrical problems with the car. If you want to rule out the battery, make sure it's nice and solid at 12V, wipe all the codes again, and pull them again.
Old Mar 3, 2021 | 01:04 AM
Mason8383's Avatar
Mason8383
Thank you for the thorough response. For module 4, I had no codes shown up to begin with, I should've clarified that from the beginning. As for the CCM failure codes, I have seen a post from a 94 vette owner that had the same exact codes come on after having reset everything. Nothing I can rule out at this point and I don't look forward to messing with my dash cluster. I saw some of my previous codes were related to shorting out, not sure where exactly, but I saw them in the history. Tomorrow morning I will reset my codes and have my car run and try to get it to die out. Last time I drove it tonight it was running just like it always used to. Hell, ive driven that thing from Houston to Austin and back all in one day about 4 months ago.
Old Mar 3, 2021 | 10:35 AM
  #33
BillyVette94's Avatar
BillyVette94
I would spend some quality time going thru the wiring around the engine and checking your ground points. Check the harness that runs by the right valve cover and goes down to the opti. That harness does alot of things. Get a multi meter and check for continuity with your wires and grounds. Do what Nomake said. Get the EEhack and the cable. Good luck..
Old Mar 3, 2021 | 12:17 PM
  #34
Mason8383's Avatar
Mason8383
I will do that. But wouldn't the code reads that pop up with shorting pin 4 to 12 work just as well?
Old Mar 3, 2021 | 12:21 PM
  #35
Mason8383's Avatar
Mason8383
I reset my codes today and restarted my car. A new set of codes popped up. As follows:
Module 1:
C12 (clear again)
Module 4:
H82
Module 9:
Module A:
C51
C52
C71
C76
H24
H42
H51
H52
H61
H62
H71
H76
a bit confused on why it would throw the old history codes from Mod A at me again. What could this signal? Also, H82 is new, have not seen it before.
Old Mar 3, 2021 | 01:18 PM
  #36
jmgtp's Avatar
jmgtp
Wow man, you really need to datalog the thing, that will show you what is changing in the moment that it quits. Intermittent problems suck, the car is trying to tell you what’s wrong you just need the right setup to see that info. Otherwise we’re just taking guesses with you and you might end up replacing good parts. Seriously, cable is a small investment. Software free. Have an old laptop?
Old Mar 3, 2021 | 02:12 PM
  #37
Mason8383's Avatar
Mason8383
I just bought the scanner today and have the software for it ready.. im going to go diagnose it again.
To C4 Death Trap
Old Mar 3, 2021 | 02:36 PM
  #38
Nomake Wan's Avatar
Nomake Wan
Shorting those pins only tells you trouble codes (and lets you reset trouble codes, and cycle some CCM inputs, and check some CCM inputs and outputs). Connecting a laptop lets you do all of that as well as log realtime data from the car (and reprogram the PCM but we won't bother with that right now). It's hard to explain just how much more useful a laptop with a cable is than literally any other electronic tool for a 94-95 Corvette.
Module 1:
C12 (clear again)
Module 4:
H82
Module 9:
Module A:
C51
C52
C71
C76
H24
H42
H51
H52
H61
H62
H71
H76
Module A seems to very much think that your car has been in an accident severe enough to pop the airbags. Module 4 H82 is Transmission 1-2 Shift Solenoid Circuit failure.
There are some very serious electrical problems on your car, it would appear. As an earlier poster said, it makes me wonder if the shop that was doing work on your car failed to reconnect things correctly. Ground straps are especially important on our cars since so much of the car is fiberglass rather than metal.
Old Mar 3, 2021 | 02:41 PM
  #39
Mason8383's Avatar
Mason8383
it's weird why it is sending that code. I will go ahead and look around in my engine bay for missing grounds or disconnected parts. All they were messing with was the engine. The dash cluster and transmission have never been messed with before.
Old Mar 3, 2021 | 04:09 PM
  #40
Mason8383's Avatar
Mason8383
Update: willl no longer start, I have no way of checking codes in real time now.
