93 LT1 start up problem
Old Apr 2, 2021 | 02:02 PM
Frank Cortes's Avatar
Frank Cortes
Cruising
Default 93 LT1 start up problem
I have a 40th anniversary that all of a sudden when cold at start up, check engine light comes on the idle fluctuates then settles at high idle for a while then drops to normal check engine goes off and performs fine, like nothing was ever wrong. I replaced the Prom, sent the ECM to SIA electronics and got it reflowered, replaced all sensors, optispark ,tuned, im out of ideas, it did`nt do that before I sent ECM to SIA. anybody have any ideas?
Old Apr 2, 2021 | 02:34 PM
FrankieD's Avatar
FrankieD
If you can get a datalog that would help troubleshoot.
Use Tunerpro or Datacat
Old Apr 2, 2021 | 03:38 PM
CorvetteRules's Avatar
CorvetteRules
You threw a lot of parts at a problem that you never took the time to pull the code(s) that would lead you in the proper direction. Do yourself a favor and pull code(s) now.
Old Apr 2, 2021 | 04:44 PM
Nomake Wan's Avatar
Nomake Wan
If it didn't do that before you sent the ECM to SIA, what was it doing that prompted you to send the ECM to SIA?
When you got the ECM back from SIA, did you make sure that the PROM was firmly seated in its slot? There have been reports of PROMs not being fully seated after making it through the mail causing random issues.
Old Apr 3, 2021 | 12:00 PM
Mrvettenick's Avatar
Mrvettenick
Get a good scan tool to find out why that light illuminates. If you can't/don't want to buy one, then go to Autozone, or someone like that, and they'll pull codes for you for free. Without codes or looking at data, you're working blind. And buy the factory repair manual. You'll save in the long run.
To 93 LT1 start up problem
