1984 Corvette Cranking Problem
Old Apr 2, 2021 | 02:37 PM
xDBZ Overlord's Avatar
xDBZ Overlord
3rd Gear
Default 1984 Corvette Cranking Problem
I have a 1984 C4. For as long as I have had the car, it's had one persistent issue. Sometimes, seemingly at random, when you attempt to start it, all you hear is the starter and not the engine cranking. I thought putting in a new ICM would have fixed the issue, but it has not and now I am kind of stumped. Ive never really ran into an issue like this before and I don't really know what the culprit . Anybody know anything?
Old Apr 2, 2021 | 04:29 PM
ajp01's Avatar
ajp01
Can you be more specific? Do you mean you hear the starter spinning but the engine does not turn over and try to start? Or do you mean that the starter / engine both rotate but the engine won't fire into an idle?
Old Apr 2, 2021 | 04:32 PM
xDBZ Overlord
3rd Gear
Yeah, sorry about that. The starter spins, but the engine doesn't crank. Usually when this happens it takes 2-3 tries before the engine finally starts to start cranking
Old Apr 2, 2021 | 04:49 PM
ajp01's Avatar
ajp01
That sounds like an intermittent problem with the starter itself (Bendix drive pinion) rather than ICM or ECM related. Others can chime in as they see fit.
Have you replaced the starter since this started happening? Or has it been the same one all along?
Cheers.
Old Apr 2, 2021 | 09:56 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Anyone would tell you it's the starter
Old Apr 2, 2021 | 11:32 PM
xDBZ Overlord
3rd Gear
Thanks, the only people I have talked to about this have told me its not the starter, so I decided to look into other areas that could be causing this issue. I'll get one ordered right away and post an update after its installed.
Old Apr 3, 2021 | 12:14 AM
mike1111's Avatar
mike1111
starter
Old Apr 3, 2021 | 02:27 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I'm still wondering how the ECM has anything to do with the starter working and the motor is not physically cranking? Maybe your just not explaining it right? I would HIGHLY suggest that you get a 84 GM service manual. It has a lot of good troubleshooting information in it and is worth its weight in gold for sure. GL
Old Apr 4, 2021 | 07:54 PM
caverdan's Avatar
caverdan
I would pull the starter out and inspect the flywheel teeth for strange wear patterns or possible missing / broken teeth.
Old Apr 4, 2021 | 08:55 PM
Cruisinfanatic
If the starter is working but the engine is not turning, of course it's a starter problem
To 1984 Corvette Cranking Problem
