Transmission swap
Old Apr 2, 2021 | 11:27 PM
MyLT4CE's Avatar
MyLT4CE
4th Gear
Default Transmission swap
Been a lurker for a long time here. I have a 96 LT4 vette and am looking to swap out the ZF6 and go to a 4L60E auto. Has anybody done this? Searched this and most if not all answers were for the other way around... auto to manual. Can anybody point me in the right direction on what is needed for this. I figured the E model with a stand alone controller would be the way to go but need advice on the cooler setup since my radiator does'nt have the cooling capability due to the manual. Will it bolt up to theLT4 block? I would probably need a new driveshaft also plus the crossmember as well? Any help is greatly appreciated
Mike
Old Apr 3, 2021 | 05:27 PM
AZSP33D's Avatar
AZSP33D
Mike
Can you find an LT4 auto owner to swap, perhaps side by side? most people would want to swap the other way. No crossmember on the C4 BTW... Look at console plate, shifter, wiring, ECU, bellhousing, perhaps dash, C-Beam, pedals, yoke, lots of little details.
Old Apr 3, 2021 | 06:12 PM
arbee's Avatar
arbee
Also no such thing ^^^^
Old Apr 3, 2021 | 06:44 PM
AZSP33D's Avatar
AZSP33D
Right, LT1 car swap.
Old Apr 3, 2021 | 10:00 PM
Benny42's Avatar
Benny42
Do not butcher a real CE LT4 car please. Sell it and buy an Automatic car. This is strictly my opinion, its your car, do what you want to it, etc, etc.
Old Apr 3, 2021 | 11:42 PM
arbee's Avatar
arbee
This ^^^^^
Old Apr 4, 2021 | 12:17 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
X3.
You could sell the LT4 car, buy a similar condition LT1 auto and have plenty of change left over to mod the LT1 auto up to LT4 power....or beyond.
Old Apr 4, 2021 | 04:53 AM
glenx122's Avatar
glenx122
Seriously, just sell the car and buy an automatic.
Case closed.
Old Apr 4, 2021 | 09:57 AM
RichS's Avatar
RichS
You can do using factory parts. I swapped my GS to a 700R4 and use a separate controller for lockup. Using a 4L60E you would be able to repin the computer and add the auto harness and reprogram the computer for the auto. You need a auto yoke to swap on your driveshaft, can reuse the c-channel. I swapped the pedals out, used a factor shifter and trim plate. Funny how people look inside and at the vin and are confused about the auto in the GS.
Old Apr 4, 2021 | 12:12 PM
383vett's Avatar
383vett
I swapped my 4+3 to a 700r4 and finally to a 4l60e. I used all factory parts except for the TCI transmission controller. I compared the 84 parts manual to the 85 and assembled the necessary parts. As far as the pedal, just remove the clutch pedal. I footbrake at the drags and the brake pedal still works.
Old Apr 4, 2021 | 03:42 PM
MyLT4CE's Avatar
MyLT4CE
4th Gear
Thanks for the reply's. It was a driver when I bought it about 7 years ago with 80,000 mi. on it. I've slowly changed and rebuilt it with the last project being the engine. I had Karl Ellwein build a 383 stroker for me and its finally up and running. It's build # 87 on his site in case anybody is interested. Thats the reason for wanting to keep this car. It's still very much a work in progress but at least its drivable and is one awesome ride!
I have theTorqueHead conversion on it so I still have to find out from them if the swap is compatible with the new ecm as it was programmed for the manual. I read about the stand alone controller for the 4L60-E and thought this would be the way to go as you can set shift points and lockup at the control module. Thanks for the tip on the yoke. Did you have to change the driveshaft? Does the ecm have any input to the ZF6 now?
Thanks again
Mike
Old Apr 5, 2021 | 07:23 PM
RichS's Avatar
RichS
Thanks again
Mike
You need the auto Yoke to replace the M6 yoke but use your original driveshaft.
The ZF really doesn't have any input other than the speedo. I swapped my ZF speedo ring and sensor into my 700R4 and it works fine.
With HP tuners you can change the trans setting from standard to Auto and set everything. Paul (From torqhead) may have the diagram on the website or will send it to you if needed, (I run this also) You would just have to add the harness for the auto. A stand alone controller would work also. You would have to move the clutch switch to the auto shifter and reverse lights.
Old Apr 5, 2021 | 08:19 PM
MyLT4CE's Avatar
MyLT4CE
4th Gear
RichS... Thanks for your input. I think I just found my next project. I really appreciate the help.
Mike
Old Dec 4, 2025 | 02:26 AM
bdeal1215's Avatar
bdeal1215
3rd Gear
Default LT4 auto
I have a LT4 grand sport automatic. So never say never.
Mike
To Transmission swap
