Cold Air Intake Advantage?
Old Apr 3, 2021 | 06:12 PM
mfowler's Avatar
mfowler
Default Cold Air Intake Advantage?
I'm considering installing a cold air intake on my 1990 L98. I'm looking at a Vortex.
1. Is the added performance really worth the money?
2. How much of a pain in the a** is it to install?
Any opinions greatly appreciated!
Old Apr 3, 2021 | 06:35 PM
aklim's Avatar
aklim
I haven't seen anything besides a placebo effect.
Old Apr 3, 2021 | 06:36 PM
ChumpVette's Avatar
ChumpVette
Zip, zilch, nada, nothing.
Buy a factory air filter and call it good.
Old Apr 3, 2021 | 06:42 PM
JoBy's Avatar
JoBy
The stock intake system is a 'cold air' type.
Old Apr 3, 2021 | 06:54 PM
aklim's Avatar
aklim
I think the advantage is that you can do show and tell to people who don't know better and get adulation of those guys.
Old Apr 4, 2021 | 10:49 AM
TexasDjj's Avatar
TexasDjj
Cruising
I was looking at the same mod - the responses from the pro's that have shared with you already sum up what I have researched as well.
It will look Kool - I also heard from pro's on this forum that "cutting the cowling" would also improve air flow - I'm searching for a picture from someone that has done this already.
Old Apr 4, 2021 | 08:38 PM
gman35's Avatar
gman35
****** up a A/O forced air intake set up when you get a chanch,,,, Then send me a pm and I will share some experience with you. Better yet give me a pm and I will share what I have before you do anything.. Gggg
Old Apr 4, 2021 | 08:43 PM
aklim's Avatar
aklim
Question is, even if you could improve the air flow, can you really use that extra air? This may be a case of "some is good, more must be better". Is your TB going to flow that air?
Old Apr 4, 2021 | 09:00 PM
CorvetteRules's Avatar
CorvetteRules
If you put a decal in the rear hatch window that says "Cold Air Intake" you may add an extra 10 or 12 HP.
Old Apr 5, 2021 | 10:19 AM
vader86's Avatar
vader86
I have one, the SLP type, it sounds cool, it does nothing really.
Old Apr 5, 2021 | 03:00 PM
mfowler's Avatar
mfowler
Thanks for the info guys! Guess I will use that money for new weatherstripping. Sounds like a better investment!
Old Apr 6, 2021 | 12:19 PM
playsdixie's Avatar
playsdixie
put one on my 85 a few years ago....no difference at all...now looking at the cost of restoring back to stock...replacing what I cut...
Old Apr 6, 2021 | 12:23 PM
AgentEran's Avatar
AgentEran
There may be negligible gains for cold air kit, but cutting the air lid does reduce restriction and makes a difference.
Old Apr 6, 2021 | 09:58 PM
aklim's Avatar
aklim
You don't really think your butt is going to notice a few HP when the car is surging forward, do you? Are you THE PRINCESS?
Old Apr 7, 2021 | 12:08 PM
bjankuski's Avatar
bjankuski
Every 10 degree drop in air temperature is 1% in engine power. The cold air intake is a great way to get the most out of what you have in your engine. Monitor the air inlet temps on your car in stop and go driving in the summer and you will see 150 degrees plus. On the highway the difference is not so dramatic but it is worth doing in my opinion. I have the SLP intake and it works great.
Old Apr 12, 2021 | 10:23 AM
TexasDjj's Avatar
TexasDjj
Cruising
Hello aklim - thanks for your input. I don't know if "more air" will help or not. I just got this 1990 C4 w an L98 motor in it for my son and I'm trying to do some "easy 1st mods" to improve performance. For me this motor is not real impressive as it is - good top end, but my wife's Cadillac SUV will blow my vette's doors off - and that just doesn't sit right with me!
Old Apr 12, 2021 | 01:08 PM
aklim's Avatar
aklim
Intake, headers and a chip tune will be a good start
To Cold Air Intake Advantage?
Old Apr 12, 2021 | 01:21 PM
ChumpVette's Avatar
ChumpVette
Unless you want to dump money, you had better learn to live with it.
Old Apr 12, 2021 | 01:22 PM
ChumpVette's Avatar
ChumpVette
And just to clarify, that "intake" is not the air box, but the actual intake manifold.
Old Apr 12, 2021 | 01:24 PM
aklim's Avatar
aklim
Or trade it in for something more satisfying before you get upside down in the quest for more power. It can be done but it is easier with the newer systems.
