dizwiz24 massive modifications
Diz, get a dragy or P gear, scale the car and tune that beast up and get some times. 60-130 or custom 40-100 times can really help you out. No need to drive a couple hours to the track.
12 lb flywheel ipo of 40 lb stock dual mass one
manual seats instead of the power one.
removed spare tire (though an 8 gallon methanol tank resides there)
removed A/C system. (Though a supercharger head unit was added).
6 point cage ??? I cant inagine it adding more than 80 lbs
removed vert x brace (im caged - didnt see need for it).
Lightweight baer eradispeed 2 piece 13” rotors.
removed rear storage console lids
me at 155 lbs
http://www.pszweb.com/car/gears.htm
5300 rpm is only good for 114 mph in 4th gear w-3.45 and 810 rev/mile tire. 6000 rpm gets you to 129 mph which is only C6 Z06 territory (~440 rwhp). For the lofty goals, a 140 mph trap speed target should be in order, which means ~6500 rpm with current gear and tire. I already forgot what I was going to say next. Mongo likes candy.
For the record. i never stated a 140 mph trap speed goal.
i said i only revvd it to 5200-5300 rpm during my test run the other day . So I could look at fuel trims and knock activity before revving higher
i mentioned I am seeing 14+ psi boost at 5200-5300 rpm.
Since I have a centrifugal blower, that boost is gonna increase with rpm, so i stated a 6000 rpm rev limiter considering my stock bottom end.
by 6000, i will likely be seeing 16-17psi boost.
my 60 ft is the problem.
so are they saying ill need to plan on a 140 trap to make up for a lousy 60 ft?
if so, i have a problem with that statement. They are assuming I wont be able to ‘learn’ or ‘improve’ it any - like im some kind of retard, incapable of learning.
ive clearly stated the problem of over crowding at the tracks. I can spend 6-8 hrs there and get to go 2x, if im lucky.
During that 1st run, knowing it may be my only run, I purposefully launch conservatively so I can datalog a full range of data without having to ‘lift’ in 1st bc I was too aggressive with the clutch dump at launch.
this data is critical.
Am I getting false knock at the launch ? And should i turn off the knock sensors in that range?
Am I getting real knock on the big end ?
how are my afr’s ?
there isnt time to ‘learn’ a technique on my 6 spd car.
I need a private track rental vs JoePublic test and tune.
coupled with an hour+ drive to and from the track, it can be a day waster
I was just pointing out that aiming for 140 is pretty far out there. I know your weren't claiming 140 as a goal Diz. I was responding to Tequilaboy.
I have the same issue with going to the track. 70 miles oneway and no idea how many runs I will get. Plus last time out I broke it and had to tow it back at a $400 expense. I know it isn't the best thing to do to test on the street but rolling start testing/tuning is pretty easy on the car if you can find an open road. You can also do a bunch of 0-60 type runs and coast through the 1/8 mark and get your 60ft times with the dragy or P Gear. Not that they are all that accurate but you can simply subtract 4-5 hundredths and it would be really close.
I am in the process of more mods myself. I am going to install the Tilton flow control valve soon and hopefully that can cure my inability to finesse the clutch pedal and get my 60s down into at least the 1.8s.
IDK if "140" is the precise, exact, on-point number that you need to trap to match or beat these cars that you say you want to beat, but Tequilaboy is right that you need to make up for a bunch of shortcomings with hp and trap.
I think that you should get your datalogging/tuning done on an abandoned street...then focus on your driving at the track. Working on tunes at the track IS a "day wasted".
At least that seems like a more reasonable goal now. Won’t prove anything as your boisterous attitude seems to suggest all the time, but best of luck to you on getting it done. The mods all look solid, and I love that spare tire well fuel cell setup.
In reality there is little reason to run more then the 1/8 for true test and tune. Can practice your launch, shifts, and even data log for tuning.
Another point that you probably don't want to hear, but get a set of wheels and put some mickey Thompson drag radials on for track use.
They will be more consistent, help with wheel hop, and hook better then any autocross or street tire.
My 87 was running high 10s and regular low 1.5s (personal best on that combo of 1.48s). When I moved to the 408 with the F1R, the car would repeatedly 60" in the high 1.6 to low 1.7 range. I have never run the larger blower combo on slicks, as I suspect I will be back to breaking driveline parts (McLeod clutch, ZF6, 3.33D44).
If one has a slow 60', you must 'freight train" on the big end to compensate..
Have a screen capture in my C4 Corvette hood scoop saved files?
Maybe that will jog someone's memory.
Cold Air Intake Test Results
https://www.corvetteforum.com/forums...t-results.html
If it is not too difficult to post a pic, I'll gladly share a few pics of my set-up. Do we still have to pay for a photobucket acct? The FB groups are so much easier.
https://www.corvetteforum.com/forums...-pictures.html
