a/c delete question
Old May 7, 2021 | 04:03 PM
sb66's Avatar
sb66
can you remove the condenser in front of the radiator without having to change anything? looks like the 2 of them are held in by the pressure from top and bottom casing?
Old May 23, 2021 | 05:48 PM
sb66's Avatar
sb66
is this possible? could even eliminate the tensioner and put a adjuster rod on the alternator - maybe - this way I would not have to change the water pump yet - I am going to eliminate the smog stuff since the bearings sound like they may be going - I know they have delete kits But i was seeing if this may work to avoid adding anything else at the moment ?
thanks delete altogether
A/c delete
File Type: pdf
Old May 23, 2021 | 07:15 PM
project C4's Avatar
project C4
Old May 23, 2021 | 08:09 PM
sb66's Avatar
sb66
excellent - so you used a longer adjuster in front of the alternator - what did you connect that to? you also used a different hose and re-routed it? removed tensioner? (sorry so many questions)
