My LS build thread v 2.0
Mine is 3" with x-pipe and straight through Flow FX bullet/glasspack mufflers.
https://m.youtube.com/watch?v=y2OMcx...ature=youtu.be
When I pulled the differential last year, I ran the car a little while with and without the x-pipe. (my neck down to 2.5 is near the mufflers after the x) It made a very substantial difference in idle... loudness I guess. Without the x it reminded me of a friends old race boat... just ridiculous for a street vehicle... works fine for a boat competing offshore though lol. The x calmed it down a lot at idle but... wide open was still too much. I got on it well over a mile from my friends house and got a text almost immediately asking if that was me followed by a never mind I figured it out when I turned down his block. I like it as much as the next guy but it was a little too... racey for me even at 25. That's why I abandoned the cutouts idea months ago. I'd never use them.
I struggled with idle tuning for what seemed like forever. I went through 10 gallons of fuel until I got it figured out. I don't know if that shows perseverance, stubbornness or some level of mental retardation. But either way I finally have it idling with an IAC the way she should. So this is what I had to do.
First I didn't want to spend the money but I bought a Nick Williams 102mm throttle body. The ebay throttle body was sticking a little and was also leaking vacuum. So I figured before I wasted time trying to tune for idle I wanted to put a good throttle body on it.
I was a little mad at first because with the new TB the idle quality didn't change. So I had to look at the tune. In my defense I have never tuned an engine with this big of a cam or intake or with this much compression. Holley used a base idle timing of 12 degrees. So I upped that to 18. Then I jumped the timing in the 600-700 range to 26 deg. This creates a "lip" so to speak on the timing map. Basically it helps the engine stay alive if it starts to stall. Then I smoothed out the rest of the timing curve. I have 25 deg up top at WOT and 18-19 at idle.
After that I messed with the IAC settings. I was able to get it to run better but it would still stall from time to time. Then I found out the big issue. Holley set the idle air fuel ratio to 13.8:1. With it this rich it's no wonder it kept stalling. So I leaned out the idle and cruse AFR to 14:1. I know this is still rich. Wow did that help. Now she idles very smoothly at 875 rpm.
If it would ever stop snowing or freezing rain I might get the hood bolted back on and take her out soon. Just waiting on the weather now.
There have been a lot of comments on my YouTube channel asking for a driving video. Or at least one of me talking about drivability with everything done. So when the weather breaks I think I'll steal my kids GoPro again and make one after I get the fuel map a little more dialed in.
So, I still have a lot of work to do on the tune. I did a data log while driving. I only drove about 10 miles. I was having a little trouble with the IAC. It's getting stuck for some reason. So, I'm going to try either a new Delphi or ACDelco IAC. The one that's in it is a Holley. The pindle on the end had popped off at one point and I jammed it back on. I'm sure it's not right. That and my current fuel map is almost as lumpy as my driveway.
I'm also getting a lot of surging. I'm sure it's because the timing table isn't much better than the fuel table. But all in all, it seems to run pretty well. I will say that the big cam and the big stainless headers make a lot of noise. At first, I thought it was a tapping from the rockers. I pulled a valve cover to check the torque. Then I thought it was the injectors. Turns out this is a common LS issue. Big cam + big tube stainless headers = tapping that will drive you nuts! I found a bunch of posts about the subject on LSTech forum. It did get better with the hood on though.
So I think with a new IAC and a few more data logs in learn mode I should be able to have it dialed in. I will say though the throttle response with 11:1 compression is nuts. You have to be carful bumping the throttle. She gets a little jumpy!
I also drilled and tapped the intake for the nitrous nozzles. I don't have the nitrous parts yet. I told myself I had to stop buying stuff with Christmas so close. But shortly after New Years you better believe I will have nitrous parts and an M1 carbine I've had my eye on.
Sorry to hear about the snag, I know it's after the fact but an old trick is to insert a portion of a length of rope thru the spark plug hole. Stops the piston and allows the balancer bolt to be removed and reinstalled.
