Positive battery cable help!!!
Old Dec 15, 2002 | 10:12 AM
96 CE LT-4's Avatar
96 CE LT-4
Default Positive battery cable help!!!
Hello all! Well my battery has decided to puke battery acid all over the place and it has taken out the bolt to the positive battery terminal. In despiration to get the battery out of the car i decided to cut up the positive battery cable. Now my problem is that i went to buy a replacement at the local pep boys and they give me a different cable, my cable has 3 wires coming out of the positive cable, 2 red, 1 black. What the heck do all of these do and what part do i need to order. Any help is greatly appreciated! I miss my baby! :confused:
Old Dec 15, 2002 | 11:10 AM
CNTDRV55's Avatar
CNTDRV55
Default Re: Positive battery cable help!!! (96 CE LT-4)
I have an LT4 also, and the two small leads go to fuse boxes that are located an either sides of the battery within ~6in.
I am confused as to why the new cable looks different from the original one that you cut up! :confused:
What you described from Pep Boys sounds like it is correct.
Old Dec 15, 2002 | 11:42 AM
96 CE LT-4's Avatar
96 CE LT-4
Default Re: Positive battery cable help!!! (cgtarga1)
The one from pep boys would be good enough to go from one fuse block, but thats it. How do i tie all 3 in together so that i can connect to the battery? Thanks
Old Dec 15, 2002 | 12:24 PM
96 CE LT-4's Avatar
96 CE LT-4
Come on guys!! Any help is appreciated!
Old Dec 15, 2002 | 01:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The large wire that goes from the battery to the starter carries all of the current to the starter and main circuits. The small wires supply the auxilary circuits that always have power.
My recommendations would be to go to a Chevy dealer and get the origional style cable OR splice some 10 guage stranded wire into the large cable.
I would find some large shrink tubing that will fit over the large cable, then just about an inch or so from the battery connection cut a 1/2 inch wide section of insulation all the way around the large cable. Then I would weave the 10 guage wires into the strands of the large cable and solder them in place. You will not be reducing the current carring capability of the large cable. Then all you have to do is heat shrink (I would do two layers of shrink) the area where you spliced in the wires. Then I would solder the small aux wires to the ones that come from the fuse boxes.
It should work just fine.
Bill C ;)
Old Dec 15, 2002 | 01:07 PM
96 CE LT-4's Avatar
96 CE LT-4
Default Re: Positive battery cable help!!! (Bill Curlee)
Thank you so much Bill!!
To Positive battery cable help!!!
