GM 700r4
it have 40k orig miles on it. converting to 5spd(for now).
You can have it for $850, but i would know how to ship it
so you can come check it out and if you like you can take it with you,
I'm in northern NJ.
LMK. - email me
My 2 cents, I'd shy away from the dealer. I had my 700 rebuilt and 3 months later it stuck in first gear. I took it to William L. Morris Chevrolet in Simi Valley and they wanted to rebuild it again for 3,800 dollars. I asked them if they could just please take out the valve body and blow out the passages as the trans had been rebuilt 3,000 before. Debri afer a rebuild can cause a stuck valve. After hours of arguing they did it (said it wouldn't work) and charged me 250.00 and the trans has been running just fine for the past 3 years.
AAMCO is another one I would shy away from as well as Leon's Transmission "(805)522-0230" those ones with franchises tend to pull scams. If you need the owner's or manger's names I can provide them they know me. The people who work at these establisments tend to bounce around between shops, so the manager of AAMCO might be the manager of another shop franchise in 2 months. This same car (mine) was taken to Leons (who now work for AAMCO) with 17 miles on a fresh rebuilt trnasmission that needed an adjustment. And in this case I did get bitten for another rebuild of almost 1,800.00 with only 17 MILES. I am just too old to deal with nonsense and when you take a vehicle somewhere expecting qualityyou get crap. We all have our own jobs to do and expect honesty...not. This ended up in court They talk a lot about the minimum rebuild the law will allow and that is what just what you get, the minimum (sometimes nothing) for high dollars.
I have had the best luck with local shops who need your business and want you to return as they are just like you and me. If you have the knoweledge or the time it works better overall to remove the trans yourself and drop it off. Or pay someone to remove it in your garage. Not to save money, but there is less damage to your vette that way. These clowns don't give a darn about your car. One shop said to me just after a rebuild "It runs fine, I tested it myself on the freeway at over 100mph... Great pal, duh, I'll be back next time I have a problem. When I said OKAY, let's go for a drive, we did, he drove. My 84 did in fact drive up Los Angeles avenue Simi Valley CA while I sat shotgun in a school zone at 100 mph, he wasn't kidding. The transmission did not function properly, but we did drive that fast, so he must have been right. Jeeeez. We had to go that fast to get the car to shift into 4th gear, WHICH was the original problem I sighted to him. He still didn't get it. Local shop is my choice, not for the money but for the longevity of your trans.
thanks
joe
The clutch plates are stacked one after another so EACH plate have the same clamping force.
Buy two bathroom scales.
Put them side by side and stand with one foot on each. Like your nail example they will both show half your weght.
Not stack them one on top of the other and step up onto them. Both will now show your full weght.
There are two sets of clutches at work, the flat plate clutches mentioned here, and a band clutch that wraps around the outside of the shell assembly. Neither have a LOT of clutch material on them (like a standard tranny), they tend to fail when they're applied slowly, generating heat and scraping off the clutch material. The object is to improve the tranny such that it has increased friction AND increased clamping power so that it'll live.
Another oddity is: Bunches of Tranny people can make the 700r4 live behind 450hp or so. Fewer claim to make trannies that live behind 750 hp. There are only two or three weak points that seperate the two ranges. So if you build a tranny to take more than 450, it should be good to go for anything less than 750 or so. IF you've got a guy claiming 800 hp, he's lying. It take a BUNCH of work and expensive bits to get it to run past 750. (Which Brian can do, but it costs cubic dollars.)
Good thing mine's good for only about 500hp. :rolleyes: There are some folks out there making SCARY Crazy horsepower.
It makes a dramatic improvement in torque capacity. If you want to argue against the 25% increase in torque capacity here, you may as well be pissing in the wind.
I can see where you may have a differing opinion on it...especially if you ever had a bad experience from a BS rebuild con-man who promised the moon simply from adding the extra plates, and then ended up with a POS trans....but in reality, it's a real improvement in durability of the trans.
[Modified by BBA, 9:51 AM 12/21/2002]
This is not the same thing as your nail example.
1. there are a bunch of people working on transmissions that don't REALLY know how to make them live with more than OEM power levels. The throw parts at them until they stop breaking and call it done. If they CAN'T fix the tranny that way, they give up and take the TH400 route. There's a small group of people who aren't giving up on the700r4 and are continuing to develop for it. Why? Because a 700r4 is a hydraulically actuated 4l60e. and What do ya think is in the C5? Yup, a 4l60e. To give up is to consign yourself to a gradually smaller and smaller share of the market.
2. A transmission that can handle 10 hp more than you make will live indefinately. IF you have such a beast, and you never cook the tranny fluid, and you service it at regular intervals, you'll be a happy camper. But if you've got MORE hp than most tranny builders know how to build for, it's a friggen crapshoot trying to find one that is worth throwing your money at. If you buy one from an out-of-towner, You're pretty much screwed when it doesn't live. Even if they do support their warrantee claim, you're out that second R&R, time, and shipping.
If you don't LEARN about how the transmission is supposed to work (which I'm doing now) then you're stuck with whatever your tranny guy throws at you as 'normal' until it dies on you, stranding you somewhere and costing you another couple of grand...
My history report on my personal experiences with the 700R4 are....
bought my vette with 150,000 miles on it.... raced it apprxomiately 600-800 passes over several years and put 40,000 miles in it before the 3-4 clutch pak decided it wasn't shifting at wot anymore. This was in a 12 second car with a 2500 rpm converter. This was an early core... I have no idea how long that tranny was in before I got my hands on it.... with all I know it was the orginal untouched 700R4
At 190,000 miles put in a new later core 700R4 built to stock GM standards. Put in a 383 and 3000 rpm converter and small tranny cooler.... have now put over 600 11 second passes and over 30,000 street miles on this transmission and it still runs exactly the same as when I put it in..... I changed fluid in it once.
My tranny pretty much gets beat on as hard as anybodys... it sees 50 miles of stop and go traffic everyday on the 405 freeway.... and then is forced to go to the track most weekends to be beat on..... and it has never cost me a race. Has a loose converter which builds up heat too.... but still keeps going.
The only time I have touched it.... I put in a transgo shift kit that didn't work out.... shifts were mushy, so went back to the stock valve body 2 weeks later where it shifts fairly firm.... but wouldn't call it hard hitting.
As another note, forum member LT401vette in his 550-600 hp LT-1 that runs mid 10's @ 125 + mph rebuilds his own 700R4's.... his trannies typically last 15,000-20,000 miles between needing to be freshened up..... very reasonable considering the power.
Sorry to hear about all of the 700R4 failures out there.... really shouldn't be happening.. don't know why it does, maybe some of the tranny builders try to get too fancy with them or something ?? Dunno.
good luck
Beach Bum
I will tell you right now that pro-built trannies probably has one of the strongest most dependable 700r4 trannies out there. Dana is great to work with and his trannies are ~1300+shipping. They are built for racing and hold up to the harsh treatment we put them through.
Mine works flawlessly and would not hesitate to get another from him. He said he has several out there that have been turning low 10 sec 1/4 mile times and is yet to get one back. He said the one guy live near him in california and wanted to have it take the one apart and give it a once over during the off season. So he did, said EVERYTHING looked perfect, and this was after several seasons running 10 sec behind a 600+hp engine.
For the money I wouldn't even talk to anyone else. I only know Dana through buying my transmission, and a lot of research.
If you need anything let me know.
:cheers:
Check out Danstrans....they specialize in TH700R4s and build the toughest trannies
Ohh BTW ......LT401Vette with his 800hp LT1 has a danstrans in his car.....
http://home.nycap.rr.com/danstrans/
:yesnod:
[Modified by Alex D, 11:15 PM 12/21/2002]
[Modified by Alex D, 11:22 PM 12/21/2002]
cheers,
Beach Bum
[Modified by Beach Bum, 7:44 AM 12/22/2002]
His last several rebuilds were done by himself using select parts he chose.
In order to afford this tranny rebuild in my Twin-Boy-Constrained budget, I'll be doing most of the gruntwork labor myself, _hopefully_ by the time I'm done with this, any future work can be done by yours truely. I've worked on damn-near every other part of the car, the tranny has always been a 'black box' that I was afraid to touch. Now it's just an assembly of parts with tolerances I don't know yet -- that'll have to change. :hat
Beach's Vette is a great example of a 700R4 lasting a long time. I bet most failure's are because of the builder.
In my area, Long Island, I have about 4 Tranny specalist that I would take my car to for a 700R4 buildup. There are also several hundered shops that I would never trust.
Vic
Bruce at PTS seems to be one of the most knowledgible trans people from the places I've talked to. He does a lot of development for the 200-4R for the Turbo-Buick crowd, but also does heavy duty 700-R4's. He is also the moderator on the trans forum over at turbo buick, and will answer just about any questions you ask of him.
His site is http://www.2004rperformancecenter.com/
The turbo-Buick trans forum is http://www.turbobuick.com/forums/for...?s=&forumid=12
I strongly recommend reading through some of the trans-talk stuff as their is a lot of good info and experiences that I've found there.
An as Julie said, I plan to use one of his Extreme 200-4R's in "No Flight" behind a 550 HP or so SBC (plan is to dyno the engine and dial in the EFI this spring).
-Greg
My two cents from a guy that run's mid 10's...
I went through seven 700R4 rebuilds.
My vote is to go with the 400 and live with the high rev's or spend even more $$$ an go with the gear vendors set up. I pound the &%*# outta mine and when we took it apart just to look how its holding up we saw no wear at all..
Good luck what ever you do. Got a lot of good advice in this thread! :cheers:
good rebuild + lousy TC = bad experience
This also assumes you or the shop actually replaces the TC during a rebuild. :skep:
