4+3 Overdrive weird issues
Old Jun 7, 2021 | 07:56 AM
giftedpenguin's Avatar
giftedpenguin
5th Gear
Default 4+3 Overdrive weird issues
Hi,
I am a new owner of an 85 Z51 with the 4+3 (got it in February, on the road in May.).
I've seen a few issues with it lately, wondering if anyone can help troubleshoot it. I've changed the fluid in it, and have a filter on order.
Issues I've seen:
  • Press the button on the shifter, light on dash turns on, does not shift
  • Press the button on the shifter, light does not turn on, no shift
  • Light is on, car is driving, normally, no extra load (or sometimes decelerating), light turns off, shifts back to 1:1. Cannot get it to turn on again.
Yesterday I experienced the last one, and then my fuel economy stopped working on the dash. It would display either 0 or 85 L/100 for instant, 0 for average. Came to work this morning after leaving the battery disconnected for a few hours last night, same issue occurred until I got to work, then the economy readouts started working again, as did the overdrive.
Wondering if this is somehow ECU related? I could see a wiring issue, or relay issue with the overdrive by itself, but that doesn't explain the fuel economy readouts happening at the same time.
Old Jun 7, 2021 | 09:52 AM
kgrover's Avatar
kgrover
Cruising
https://www.5speeds.com/43table.htm
Here's a link that describes the logic of the shifting. The ECM gets the vehicle speed from the dash cluster, so it could have been losing the speed signal and not allowing it to engage. The ECM controls the light on the display for the engagement. If the light is on the ECM thinks it put it into overdrive. So it could be a wiring issue that is keeping it from engaging when the light is on.
Old Jun 7, 2021 | 11:11 AM
ThatOneKid's Avatar
ThatOneKid
Since you have an 85 with the button in the shifter you can remove the ECU from the control loop entirely by connecting two wires. You do lose out on the auto up and down shifts, but you have more control over the OD and can use the clutch without having to guess when it's gonna drop out from underneath you to help it live longer.
Old Jun 7, 2021 | 04:02 PM
giftedpenguin
5th Gear
Thanks, what two wires need to be connected together? Or do you have a link to a guide I can use?
Old Jun 7, 2021 | 10:22 PM
TommyFox's Avatar
TommyFox
Check simple things first. Make sure the relay pigtail doesn't look like this...Attachment 48337402
Old Jun 9, 2021 | 02:08 PM
giftedpenguin
5th Gear
So at this point I've narrowed it down to either:
  • The switch in the shifter
  • The wiring from the shifter switch to the ECM
  • ECM (looking likely since the output for the mileage isn't working either)
  • Wiring from the ECM to the relay
We tested the C and E power wires on the relay, both go hot on run. Grounding B makes the relay work and turn on the Overdrive Engaged light on the dash.
Ran a wire from B to a switch, and from the switch to ground, so I have a temporary way to activate the overdrive.
Next step I think would be to check on the shifter switch. Is there an easy disconnect for that I can get to, that doesn't involve taking the entire center console apart to get to that switch?
If that switch is OK, I'd be fine with wiring the switch in the shifter to that B wire, and using it that way, bypass the ECM entirely (really only lose out on kickdown, oh well).
Old Jun 9, 2021 | 02:14 PM
jdjenk's Avatar
jdjenk
Have to take the console out. It isn't as hard as it looks, undo the top of the shifter and then remove all the screws in the console. If you remove the bottom screws on the center dash faceplate you can usually wiggle the console out by being careful at that point.
While you're at it you can replace the switch with a toggle kind instead of an intermittent switch. Then it functions as an on/off switch instead of needing to hold it down to disengage the OD.
ThatOneKid's Avatar
ThatOneKid
https://www.corvetteforum.com/forums...-on-4-3-a.html
here's a link to the guide on the bypass, the 85 stock switch will work without replacement. Starts at post 2, I'd jump the 2 pins with a paperclip to see if that makes it work on demand.
Old Jun 10, 2021 | 10:06 AM
giftedpenguin
5th Gear
Thanks, that's what I was gathering from the wiring diagram in the shop manual as well. Just confirming though, are we connecting A7 to C8, or C7?
C8 should just be the feed from the 1st gear switch, connecting that to OD output to relay shouldn't have any bearing on whether or not the shifter switch does anything.
Old Jun 10, 2021 | 11:35 AM
ThatOneKid's Avatar
ThatOneKid
C7, the first gear switch is basically useless to the ECM after this since I believe it is only used for the first gear inhibit on the OD. The OD will remain inactive until an internal pressure switch is triggered, still not a good idea to have the OD on in first though, the pump is driven off the output shaft so it takes a little bit of speed to get enough line pressure to actuate the clutch without slippage and heat buildup, especially on a high mile unit.
Old Jun 11, 2021 | 11:18 AM
giftedpenguin
5th Gear
Thanks for the help, managed to get the connection made and it seems to be working good. Looks like I'll need to either fix this ECM or replace it.
For 85, does anyone know if they did different ECMs for 4 spd vs automatic? Z51 vs non-Z51? Cruise vs non-cruise?
Old Jun 11, 2021 | 05:20 PM
ThatOneKid's Avatar
ThatOneKid
The 85 ECU is a one year ECU, but they're all the same except for the PROM, you'll need to remove the PROM carrier and swap it between ECUs.
I doubt it is the ECU it could be a failed first gear switch preventing the ECU from enabling the OD.
Old Jun 11, 2021 | 09:16 PM
Capt Mike's Avatar
Capt Mike
Default 4+3 OD malfunction
Hi,
Issues I've seen:
Appears you have an Intermittent Electrical problem. Here's what I've found to be the most common issues. Look for corroded wire connectors or corroded Relay contacts first. The wire connectors should be clean and fit Snug on the relay electrical Terminal.
If your not sure on how a relay operates, search for Relay Fundamentals with diagrams.
The OD relay is on the drivers side mounted on the firewall, see diagram.
The heat from the exhaust does damage the relay and wire connectors, many years operating in a hot environment., check them carefully. Be aware the wires may be frayed and can fracture easily .
Spoiler
The relay contacts could be corroded, weak connection or pitted. Carefully pry up the latching tabs, remove the black plastic cover and inspect the contacts. If corroded it's best to replace the relay. You sould check the condition of the Fuel pump relay while your under the hood.
The wiring,connections, pressure switch on the Transmission could be corroded, damaged.and saturated with oil.
I've never had the trans pressure switch or internal solenoid fail or become intermittent.
I've had two Micro Switches on the OD Shift Arm fail.
Good Luck,
Michael.
problem.
To 4+3 Overdrive weird issues
