rattle question -lost -help
Old Jun 27, 2021 | 09:14 AM
sb66's Avatar
sb66
thanks I will try that - i had read that the pcv will rattle until correct vac is achieved then it should click and not rattle - is that correct? where is a good place to connect for the vac test?
Old Jun 27, 2021 | 09:16 AM
sb66's Avatar
sb66
i have these 2 lines here the forward one was disconnected i plugged it but i am not sure what they are or where they are supposed to go
Old Jun 27, 2021 | 06:55 PM
sb66's Avatar
sb66
ok i pulled the hose off of the pcv valve and heard and felt what I thought was a lot of vacuum. I will hook up the vac tester - should the connection come at the back connections to the plenum?
line with the blue arrow? the red arrow goes no where
also I have to ask while looking up some of this on the forum, I noticed i am missing things I see in other peoples pictures of their 85 - some type of covered pipe that goes from the egr to the exhaust? and some type of check valve attached to lines at the plenum - I have never had these - is this a change that occurred naturally or from a PO?
thanks
Old Jun 28, 2021 | 07:36 PM
sb66's Avatar
sb66
ok i attached a vac gauge and found at idle/neutral (manual tranny). at 149* rpm at 670-700 the vac showed was between 18-19 when hooked to the port marked in red
which at least on the gauge says "normal". I am not sure if that is or not - does any of that sound right?
