Top Storage
Old Aug 27, 2021 | 11:22 AM
Atari_Prime's Avatar
Atari_Prime
Default Top Storage
Hi All,
I'm sure this topic has been covered in the forum. I apologize for any duplication.
My C4 came with two tops. I am looking to figure out the best way to store the second top. Back in the day (a Wednesday) most people bought a storage rack for this. I don't know if those are really even available, but if so, are they the best way to store a C4 top? Is there a particular model folks would recommend? Other options? The idea of wall mounting is interesting provided its not too invasive.
Old Aug 27, 2021 | 11:26 AM
Kevova's Avatar
Kevova
A storage rack can be fabbed with abs/ pcv pipe from local home improvement center.
Old Aug 27, 2021 | 12:02 PM
s carter's Avatar
s carter
As mentioned a rack can be made out of schedule 40/PVC or you can but 1
https://corvetteparts.com/item/cart-...rage-1956-1996
But that takes valuable floor space.
Personally I would mount on a wall using a shelf bracket,Wall Ladder rack,bicycle Hooks, or the like into wall studs, and a bungee cord mounted above crossing roof then hooked to shelf bracket
Old Aug 27, 2021 | 12:50 PM
Krusty84's Avatar
Krusty84
I just use three rubber coated untility hooks mounted to the wall in my garage. Two on the bottom to hold the load and one at the top I turn by hand to keep it from falling/tipping out. Cost about 10 bucks.
Old Aug 27, 2021 | 08:31 PM
Alejandro Guerrero's Avatar
Alejandro Guerrero
Mine came with a fancy leather case/cover that It sit in then I put it in the garage on top of a thick blanket leaning against the wall
Old Aug 28, 2021 | 05:57 PM
mrlmd's Avatar
mrlmd
Wrap it up in a blanket and stick it under the bed.
Old Aug 29, 2021 | 10:49 AM
glenx122's Avatar
glenx122
a large heavy duty garbage bag in the attic.
To Top Storage
