aftermarket chip time ?
Old Sep 20, 2021 | 01:16 PM
Tim H's Avatar
Tim H
Originally Posted by c.w.moss
I am receiving a "piggyback" chip for my 1988 today. It is coming from TPIparts.net. Cost was $106 shipped. I had them reset my fan temps, do away with the egr, VATS and cold start injector. We will see how it works. Using this, if you want to go back to everything factory, just take this part out.
Im not paying 3 to 4 hundred dollars!
Old Sep 20, 2021 | 04:01 PM
tequilaboy's Avatar
tequilaboy
Looking at the circuit diagram, I think all you have to do is disconnect both the solenoid and switch and instead place a jumper between pins A4 and C15 so that the ecm thinks the EGR diagnostic switch is closing when the EGR is activated.
Old Sep 20, 2021 | 07:54 PM
c.w.moss's Avatar
c.w.moss
I just installed my "piggyback" from TPIparts.net. It is like the OP's pics. In their instructions, they say to remove the blue cover, then plug the new board into the original chip/memcal, it (the original memcal) will be sideways. Then install it into the ecu. It's tight but will fit. No need to take the ecu apart. Just got back from a short, 20 mile drive. I unplugged the 9th injector and will be removing the EGR this weekend. Runs great.
Old Sep 21, 2021 | 06:52 PM
Tim H's Avatar
Tim H
TPIparts.net. What do you look up if they don't list our years?
