1990 Corvette Dumping fuel
To the OP, I like your attitude. Totally willing to dive neck deep into your car. Good luck with this. Just please remember to let us know when you find the problem.
One way to test it would be to pull the vacuum line off the regulator, reconnect the fuel pump and turn the key on for a 2 sec pump. If the diaphragm is ruptured, you'll see fuel out the vacuum nipple.
I have checked the fuel pressure regulator. The only Thing I can think of is the new injectors are letting too much fuel pass and burning off what is left over in the fuel rail. That is why I want to see what the injectors are doing out of the intake. I only posted this thread to see if anyone has had this happen to them.
OK, once more and I'll stop beating a dead horse. Your experience is better than mine, even though mine is longer. A friend had a VERY similar thing going on with his Vette. Bunch of gas in the oil. He did a quick check of his NEW regulator by pulling the vacuum hose off, pump not running and, finding no gas, he decided the regulator was OK. It wasn't. Later, when the vacuum hose was removed from the regulator and pump run, gas squirted out of the regulator vacuum nipple. New regulator had a torn diaphragm. Another thing caused him to remove the intake manifold and it had a LOT of gas puddled in it. Probably enough to make the engine run some with no fuel pressure. Just continuing these questions in case your check of the regulator was, like his first one, without running the pump. Your issues are so similar to his, I just hope you checked the regulator with the pump running. Now I'll shut up.
Jim
Jim
Jim
Bubba sure do get creative sometimes.
IF the fuel was pooling in the intake How long would the engine run?
My L98 shuts off very quickly once the fuel pump is turned off. The 1990's don't have the Cold Start Injector do they? That would be a good source of fuel IF the car was built with a CSI, I don't think they did in 1990 but I am not sure.
If it did have that much fuel in the intake I sure would not want it to backfire at that point, that could get Ugly real fast.
Like suggested by Natty C I would bet there is alternate electrical route for power to the fuel pump.
I've only seen engines go from flooded, to lean out and stall, when the intake is full/puddled of fuel -not run on and on. That time frame from flooded/standing fuel, to stalled out lean is typically seconds....like 5-10 seconds. That engine in the vid ran way, WAY longer than 10 seconds...and ran rather smoothly and nicely to boot. Weird.
Going back to your original issue to re-summarize, and correct me if I'm wrong:
1 - Your car was running fine
2 - At some point while driving it, it started running very poorly (diagnosed as rich/dumping fuel into the engine? what were the exact original symptoms?)
3 - As a result the following were replaced with no effect whatsoever (correct?):
- Fuel pump
- Fuel filter
- Injectors
- Fuel pressure regulator
- Plugs/wires
- Distributer (cap/rotor?)
- 02 sensor
- ECM
- Coolant temp sensor
4 - You have verified that the fuel pressure goes to 43psi and holds there with key off (which points to no FPR or FI stuck issue)
That is a LOT of stuff replaced in item 3 to have no effect...was there gas in your Oil and was the car running with FP disabled BEFORE you started swapping parts? Right now it's very hard to know/separate what may be a new problem introduced vs your original running issue...so any clarification or behavior change along the way (when you noticed what) would be helpful. Also, where are you located? Perhaps a second set of eyes could help...and unfortunately it may be necessary to start swapping some of those parts back to the originals to diagnose (particularly the FPR and FIs)...
I am going to throw out some things you didn't look into that maybe could point to original problem (and can be verified without new parts):
- Clogged catalytic converter
- exhaust manifold leak ahead of O2 sensor
- Compression test
- MAF sensor
Apologies for the long post and all the questions!
