C4 headlight Timing off?
Old Dec 15, 2021 | 02:44 PM
JackCorvette85's Avatar
JackCorvette85
Default C4 headlight Timing off?
One of my headlights doesn't flip up as fast or seems like it gets caught on something I'll have to add a video later on but any idea what could cause that ?
Old Dec 15, 2021 | 03:12 PM
ajp01's Avatar
ajp01
Most likely you have one of the opening gears failing on the slow side, which is causing drag and more friction. When those plastic / nylon gears fail, they cram up the gearbox mechanism with plastic dust / powder which gums up the works also before complete failure.
https://www.corvetteforum.com/forums...post1604411483
I haven't seen your car in person so I could be wrong, but this is a likely cause.
Old Dec 15, 2021 | 03:13 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
FYI, you can simply fill the gear w/epoxy and re-assemble and that works great. Mine is going on 12 years, working great.
Old Dec 15, 2021 | 09:46 PM
glenx122's Avatar
glenx122
Replacement plastic gears are cheap.
Brass gears will last forever but much more expensive.
Job is a little complicated for a novice mechanic with not many tools.
I did the brass gears on my first car.
When the car I have now needs them I will just replace them with the plastic gears.
I figure the first pair lasted 25 years.
Old Dec 15, 2021 | 10:50 PM
ajp01's Avatar
ajp01
Good for you then. My original gears lasted 8 years and exploded, so I replaced them with brass gears that have been in the car since 1997.
To C4 headlight Timing off?
