bench testing throttle body
Old Dec 22, 2021 | 08:35 AM
johnfin's Avatar
johnfin
Default bench testing throttle body
Are there any tests or companies I can send my throttle body to that can determine the quality of my throttle body?
Old Dec 22, 2021 | 08:57 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
None that I've ever heard of. What is in question. Can you simply look at it?
Old Dec 22, 2021 | 11:07 AM
johnfin's Avatar
johnfin
Default Issue
Maybe a throttle shaft too loose causing a leak.
Old Dec 22, 2021 | 12:30 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Can't you rotate the shaft to open the blades slightly, then wiggle the shaft and see how much play there is?
Old Dec 22, 2021 | 12:58 PM
383vett's Avatar
383vett
A throttle body is not rocket science. It's a valve that opens to let air in. You can measure the play in the throttle shaft. There is a spec for that. Gotta google
To bench testing throttle body
