85 Timing Cover
Old Dec 31, 2021 | 03:09 PM
johnfin's Avatar
johnfin
Default 85 Timing Cover
Is the mark bracket originally welded on the cover or bolted to the cover bolts?
Old Dec 31, 2021 | 04:05 PM
FostersPerformance's Avatar
FostersPerformance
Should be welded if its factory.
Old Jan 1, 2022 | 09:38 AM
johnfin's Avatar
johnfin
Since they made the 350 for so many years is it an issue to getting the right cover with the timing mark in the same spot. I would image the timing marks changed over the years
Old Jan 1, 2022 | 12:03 PM
johnfin's Avatar
johnfin
Can it be removed while in the car. Pulley looks close to rs rack.
Old Jan 1, 2022 | 12:52 PM
ajp01's Avatar
ajp01
Yes it can. It's tight but if you use the tool setup that I mentioned here it can be done.
Timing cover:
https://www.ebay.com/itm/23394940808...IAAOSwbbtgZMVC
Tool setup:
https://www.corvetteforum.com/forums...post1604460845
Old Jan 1, 2022 | 01:09 PM
johnfin's Avatar
johnfin
Where did you get your cover, its different then the link you sent.
Old Jan 1, 2022 | 01:16 PM
ajp01's Avatar
ajp01
That link is actually the cover I bought. They show 1 left in stock at $21.95 price. It's the replacement part for GM part #10243967 which is the L98 timing cover.
Mercury Marine's part number for it is #14249A2 but it's the same small block Chevy cover. If my link doesn't work correctly, just go into eBay and search on the Mercury part number at left.
To 85 Timing Cover
