Hey guys, I lost 2 of those clips that hold the fuel injectors onto the fuel rail. The car is a 1996 with LT4 engine. I found plenty for the older model vettes but none for my car . DOES ANYONE KNOW THE GM PART # and where to get it from. Also the clip that holds the fuel line into the fuel pressure regulator for the 96 LT4. The dealer can't help me with these questions
Injector retainers should be available in the aftermarket. Not inexpensive but available. NAPA likely a one day order!
Point out in this image what you're needing and maybe someone can help you! It would be I'd think 'wise' to add your location. They could be right down the block!
Yes I do have OE/GM #'s but of little use for you. #22 - 17112633. NAPA can likely interchange using that information.
Thanks a lot . I'm sure ill find it with this info.
Funny thing about these clips. They don't need to be removed to pull the pigtails/plugs from the injectors. I just pulled my fuel rail and removed each clip. I lost all 8 of them. Went through this process of trying to find them at the autoparts store. They only sell them with the pigtails at about 12.00 each. So I went to the wrecking yard and got a bunch. Just to figure out you just need to push on them to get the plug to disconnect from the injector leaving the clip on the pigtail. Pushing on it releases it where removing it is difficult.
