Help
Old Feb 7, 2022 | 10:32 AM
Mattchas00's Avatar
Mattchas00
Default Help
So I made a dumb decision to buy a 1986 corvette semi **** box. Well the shifter didn’t shift out of park so I let it warm up and it shifted. Is that a thing y’all ever expected? And also the head lights won’t pop up is there any way I can manually force them up? I tried the **** but the headlight motors just click.
Old Feb 7, 2022 | 12:28 PM
Joe K's Avatar
Joe K
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
Did you disconnect the electrical connection at the headlamps? You must do that in order to manually operate them. Not sure about the shifter. Removing the console plate and operating the shifter may help you see what may be happening. Could need lubing or a bad cable. A little more information describing the problem may be needed..
Sorry I couldn't be of more help.
Joe K
Old Feb 7, 2022 | 12:33 PM
Mattchas00's Avatar
Mattchas00
Joe K
no I didn’t, I didn’t realize I had to do that thank you! As for the shifter I can’t discribe it more then it was froze/stuck in park for a bit
Old Feb 7, 2022 | 01:35 PM
Joe K's Avatar
Joe K
So would the button not push or it would but the shifter wouldn't move or... BTW the lamp connectors are fairly larger 3 or four wires in a row.
Joe K
Old Feb 7, 2022 | 01:41 PM
topfuel67's Avatar
topfuel67
There's a neutral safety switch on these cars to not let it shift out of Park unless the brake pedal is pressed. I would check all the contacts on that. I would also recommend cleaning all your contacts on everything you can. Battery, grounds, connectors, etc. There are a lot of electrical connections on these cars and they are the main cause for problems.
Old Feb 7, 2022 | 01:45 PM
Joe K's Avatar
Joe K
I have 2 85's that don't have that safety feature, never crossed my mind. Good tip.
Joe K
Old Feb 7, 2022 | 02:06 PM
Mattchas00's Avatar
Mattchas00
Joe K
oh, the button wouldn’t go down all the way
To Help
