Here’s a first:
Old Feb 7, 2022 | 02:12 PM
BMH95's Avatar
BMH95
Default Here’s a first:
Ever had this happen on one of your cars?
I guess that explains the banging clunking sounds. I thought one or more of the shocks we’re just worn out.
I’ve never seen one just pop off the bushing before, at least not on any of my cars and trucks. Can’t get my mind around how this would have happened. Luckily there’s a brand new set of shocks sitting on the bench already!
Old Feb 7, 2022 | 02:17 PM
grandspt's Avatar
grandspt
When I had the Bilstein shocks I had the same thing happen!
Glad to know I wasn't the only one.
Old Feb 7, 2022 | 02:28 PM
s carter's Avatar
s carter
Saw more than a few times when I was at the dealership
Old Feb 7, 2022 | 02:32 PM
383vett's Avatar
383vett
I can't remember is the stock setup has bushing washers.
Old Feb 7, 2022 | 02:39 PM
BMH95's Avatar
BMH95
i was just thinking maybe a fender washer would be a good idea
Old Feb 7, 2022 | 03:22 PM
BMH95's Avatar
BMH95
the service manual doesn’t show one
Old Feb 7, 2022 | 04:31 PM
grandspt's Avatar
grandspt
Nope, no washer was ever installed on mine. Although it would probably help prevent this from happening.
Old Feb 7, 2022 | 05:50 PM
WVZR-1's Avatar
WVZR-1
This is a good idea and once you see how the stud is manufactured it becomes obvious. A fender washer is pretty light, an iron washer might do better but any correct OD dimensioned would help.
An eBay search for 14105141 will get you several images, There is a couple on eBay that actually aren't correct 14105141! '84 - '87 would be 14044582.
The diameter of the stud is 15.6mm so a 14mm washer and increase the ID OR maybe a 5/8" flat washer could be ideal. The fabrication of the stud only 'isolates' the sleeve in the shock bushing.
To Here’s a first:
